Build Threads Details on Club Lexus 3IS owner vehicles
Gqwolf's Lexi
Old Mar 12, 2016 | 11:00 AM
gqwolf's Avatar
gqwolf
Default Gqwolf's Lexi
2014 UW 350 FSport w Roja Red
-Tanabes springs
-20mm spacers front and back
-painted calipers with FSport decal
-3M Gloss Black Roof Wrap
Future Mods:
Roof spoiler
FSport air filter
JDM visor
All-Fit lip (debating)
Making trip back to Japan next two years so hopefully a few more golden nuggets
No ground effects due to steep drive
Attached Thumbnails Gqwolf's Lexi-img_20160312_123116.jpg   Gqwolf's Lexi-img_20160224_201351.jpg   Gqwolf's Lexi-img_20160227_121509.jpg   Gqwolf's Lexi-img_20160312_120650.jpg   Gqwolf's Lexi-img_20160227_113317.jpg
Gqwolf's Lexi-img_20160312_123346.jpg   Gqwolf's Lexi-img_20160222_220914.jpg   Gqwolf's Lexi-img_20160227_200544.jpg   Gqwolf's Lexi-1456293490572.jpg   Gqwolf's Lexi-img_20160312_120725.jpg
Gqwolf's Lexi-img_20160226_153012.jpg   Gqwolf's Lexi-img_20160312_120745.jpg   Gqwolf's Lexi-edited_photo1458540238535.jpg   Gqwolf's Lexi-edited_photo1458501759810.jpg   Gqwolf's Lexi-edited_photo1458501639274.jpg
Old Mar 12, 2016 | 11:51 PM
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
Ouch that is a very steep driveway.. That sucks, no aero parts.. OR, you can go bags. >
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old Mar 13, 2016 | 05:15 AM
16IS300's Avatar
16IS300
calipers look awesome!
Old Mar 13, 2016 | 07:35 AM
gqwolf's Avatar
gqwolf
-Josh
True- pricey and I worry about maintenance, but that'll be down the line. I might gain a little more clearance when I upgrade the wheels.
I thought about installing at least the allfit, but with little clearance, I wonder if it'll scrape right off.
Old Mar 13, 2016 | 07:37 AM
gqwolf's Avatar
gqwolf
Thanks. 5 coats of red caliper paint and 4 coats of clear coat. Not to mention lots of prep work. Hopefully it'll last.
Old Mar 13, 2016 | 09:59 AM
Vivid101's Avatar
Vivid101
what size spacers?
Old Mar 13, 2016 | 10:03 AM
gqwolf's Avatar
gqwolf
Originally Posted by Vivid101
what size spacers?
20mm all around
Old Mar 21, 2016 | 07:57 PM
gqwolf's Avatar
gqwolf
Got my roof wrapped today. A friend did it at material cost and did it better than I could imagine. Looks great - Very happy with the outcome. Couldn't have done it without the wifey (she introduced the contact). Debating if I should continue and wrap the side mirrors and door handle like the Craftline
Attached Thumbnails Gqwolf's Lexi-edited_photo1458609773055.jpg   Gqwolf's Lexi-img_20160321_200935.jpg   Gqwolf's Lexi-img_20160321_200847.jpg   Gqwolf's Lexi-img_20160321_183711.jpg   Gqwolf's Lexi-img_20160321_183659.jpg
Old Mar 21, 2016 | 10:28 PM
Brokenis's Avatar
Brokenis
How did he remove the antenna?
Old Mar 22, 2016 | 09:29 AM
gqwolf's Avatar
gqwolf
I don't know if I did it the right way, but here is what I did:
1. Remove rear dome light cover
2. Remove bulbs
3. Use a plastic pry tool to get enough clearance for a finger to get a hold. PIA
4. Slowly pull the dome light fixture down. There are 4 metal clips that hold the fixture up. You are essentially bending the clips down far enough to where you can get a tool in there to get the clips off the headliner bracket.
5. Remove some light harness
6. Use the plastic tool to pop the headliner off the roof (by the rear windshield).
7. The hole left by the dome light and the headliner pulled down in the rear gave my small hands/arm enough room to work on taking off the antennae harness(press tab and pull brown harness downwards), then bolt (10mm).
8. After you take off the bolt and antennae, pay attention to how they fit back together. 9. I was nervous as I could tell I was creating creases in the cardboard backing of the headliner, but once reinstalled and flat, the creases go away. Time will tell if I messed up the liner adhesive.
10.You will need to remember this orientation when you reinstall.
I wish I would've taken pictures, cuz the forum doesn't really explain it well enough for me.
Like I said, I don't know if I did it the right way, but that's how I did it.
Old Mar 25, 2016 | 07:14 PM
DEMONX's Avatar
DEMONX
What's the drop on the springs you installed?
Old Mar 26, 2016 | 09:53 AM
gqwolf's Avatar
gqwolf
Sorry, I didn't measure before the install. I know I didn't want the reverse rake look that some people said they got with the rsr, so I went with tanabes. If I had to guess, it was bout 1.25". I have about 6" height by the front door and 6.5" by the rear tire.
Old Mar 26, 2016 | 09:24 PM
DEMONX's Avatar
DEMONX
Haha, that's one of the main reasons I don't want to go with the RSR downs. How's the driving ? Better thn stock or?
Old Mar 26, 2016 | 10:43 PM
gqwolf's Avatar
gqwolf
Stock is always gonna be ideal, but I would say it is comparable. I plan on replacing stock tires soon, so that should improve the ride more.
Old Apr 2, 2016 | 08:45 AM
gqwolf's Avatar
gqwolf
Washed, waxed, top coated and ready for Texas BBQ
Attached Thumbnails Gqwolf's Lexi-edited_photo1459611678820.jpg   Gqwolf's Lexi-edited_photo1459611826532.jpg   Gqwolf's Lexi-edited_photo1459611597051.jpg   Gqwolf's Lexi-edited_photo1459611762985.jpg
