Build Threads Details on Club Lexus 3GS owner vehicles
Ej's GS Build
Old Apr 13, 2015 | 10:09 PM
  #196
KingAmen's Avatar
KingAmen
Good build! Where did you hooked up your ign and headlight wire from the e- level ecu?
Old Apr 13, 2015 | 10:10 PM
  #197
KingAmen's Avatar
KingAmen
Originally Posted by SoCal_450h
what didi you use for pressure display/reading?
His using the zaetech digigauge, I just bought one too!
Old Apr 14, 2015 | 04:58 AM
  #198
uberEJ's Avatar
uberEJ
im used the Zaetech digigauge white display. its small enough to locate almost anywhere, its easy to connect, and the sensors aren't the size of a baseball like the other gauges ive seen. lol
heres a pic of the product.
Old Apr 14, 2015 | 05:06 AM
  #199
uberEJ's Avatar
uberEJ
i hooked up to the fuse box in the trunk. the fuse box is located behind the left side of the trunk carpet where theres a plastic panel. you have 2 IGN fuses there i used fuse tap i got from autozone to tap into IGN 1. heres what i used...
also you will need spare 10a fuses because the one from the fuse box wont fit into it. this is also where my subwoofer is hooked up to.
i also didn't bother hooking up the headlight. after testing out the compressors, gauges, and remote it wasn't that bright in a pitch black garage. it was something that doesn't bother me. but if you do want to connect it, i would find the headlight fuse and do the same thing like you would with the IGN. not sure if its fuse is in the trunk, in the engine bay, or under the passanger though .
Old Apr 14, 2015 | 01:00 PM
  #200
JPIVnow's Avatar
JPIVnow
Awesome journey! Thanks for the insight on your transformation...I'm a noob here as well, bout to swap to coil setup, didn't know all that was needed just to lower the car.... Now I need to think about alignment parts as well.
Old Apr 14, 2015 | 01:02 PM
  #201
uberEJ's Avatar
uberEJ
yeah the alignment parts are always a plus!
Old Apr 15, 2015 | 10:06 AM
  #202
JPIVnow's Avatar
JPIVnow
So I've been racking my brains since yesterday, so let me ask -
I plan on lowering the GS on BC covilover with swift springs...nothing crazy, cause I always got 3 kids withgroceries in the trunk
What do I need for proper stance and alignment?
I've been looking into the SPC ball joints up front & Figs Mega Arm Essential Kit. Do I need to get the rear camber from SPC if I get the Fig's Kit? And do I need the Figs rear upper links?
I'm so confused....Please advise.. Thanks y'all.
Old Apr 16, 2015 | 07:34 AM
  #203
uberEJ's Avatar
uberEJ
well the fronts you will be find with the upper ball joint since our front toe can compensate for all the lowering.
as for the mega rms essential kit... youll be fine with those. you dont really need the rear upper from spc or figs but you can get them. i have them both just to be able to freely move my suspension around.
youll be perfectly fine with the spc front ball joins and the mega arms kit from figs... im referring to this one http://shopfigs.com/v1/index.php?rou...product_id=162
they have another one on there that 750 but i think thats for the 2gs
Old Apr 20, 2015 | 05:30 AM
  #204
uberEJ's Avatar
uberEJ
well i received my suspension back from uas and placed the bags on them.
finished installing saturday and this is how it looks so far.
i have maxed out the front and cannot lower it anymore. the rear i would like to lower more even though it wont be level when aired out =). i guess i just want to tuck =P ... AWD problems ='(
Old Apr 21, 2015 | 05:07 AM
  #205
uberEJ's Avatar
uberEJ
Maxed out the coilovers yesterday and i am quite pleased =)) except for the AWD Fronts though lol
Old Apr 22, 2015 | 07:06 AM
  #206
uberEJ's Avatar
uberEJ
Got my alignment done.
its been awhile but she has been washed and vacuumed.
a little random clip my buddy made while i cleaned.
Old Apr 22, 2015 | 07:26 AM
  #207
Sleepy2is's Avatar
Sleepy2is
Any camber kit?
Old Apr 22, 2015 | 07:40 AM
  #208
uberEJ's Avatar
uberEJ
Originally Posted by Sleepy2is
Any camber kit?
if you mean do i have camber kits, yes i do:
figs rear mega arms
figs rear toe links
spc front UCA ball joints
spc rear upper camber arm
Megan rear Trac arms.
do you need camber kits, no you dont. but recommended lol
sorry i wasnt to sure about your question
Old Apr 22, 2015 | 09:31 AM
  #209
Sleepy2is's Avatar
Sleepy2is
figs rear mega arms
figs rear toe links
Sorry bout that but I'm bout to lower my car 3 inches on coils no fingure gap. Do you think I would need any camber kit? If so do I need just the front or both front and rears thanks!
Old Apr 22, 2015 | 09:57 AM
  #210
uberEJ's Avatar
uberEJ
from my experience you will need camber kit and toe links for the rear. i had an issue with not being able to set the rear toe properly becuase the bolt would adjust enough to meet my camber... i could be wrong though you may not need it.. the front you will only need camber kit if you want to straighten out your camber.
