Ej's GS Build
Replicas or not, they look really good on your ride. Take a day shot and close up so we can see them better. What'd you end up paying for them, if you don't mind me asking!!
Which BC coilovers did you go with? I've been debating between Megan Racing and BC. I think BC is going to be my choice, that ride height is exactly where I want mine to be. Do you recall what setting your ride height is?
they are just the regular bc coils with a front 14k/12k rear spring. to be warned... if you want to be at my height you will need to cut a hole in your shock tower so your upper control arms done collide with the frame. also im on max dampening in the front and rears. if i hit a good size bump my upper contral arms barely hit the frame still. but im not going to deny i love how it rides!
i will say this. i do not have any vibrations anymore and i still do have a very faint wobble from a dead stop to about like 5-10mph. its definitely barely noticeable compared to when i first lowered the car.
Had some fun this passed Monday in the ice. Our whole neighborhood was covered in ice so i decided to turn the VSC completely off using the brake method, but for some reason it wont stop beeping. i do not suggest people doing this in their neighborhood without previous experience... start off in an open parking lot
im trying to upload the other video we took during the day but for some reason it wont upload clearly.
Who did you get all this from, BC, or did you go with someone else for these parts (Rear Camber, Rear Trac Links, front spc ball joint and Rear Toe Arms??)
Lastly, why the front spc ball joints - what did this do or help?
Thanks in advance for your help!!
So, bare with me, I'm a noob when it comes to all this suspension stuff... So, you had to do a bunch of extra work in the rear end to be comfortable, yes? By extra, I mean rear Camber, trac, and toe arms. Only for the rear? Why did you do this extra work, meaning, what did each of these achieve?
ok so when it comes to lowering your car, the OEM arms don't have adjustability. The toe has that adjustment bolt but if you go as low as i did it will not align properly due to that bolt not being able to adjust far enough to match my camber causing tire wear.
if you have the rear upper camber arm, it can only go so far because there is another arm in between that and the toe arm. if you camber in more that arm in between them can get really stiff since its not short enough, like no play in its rubber bushing its connected to which can cause ride stiffness and alignment issues as far as camber. i guess too much tensions on it is what i mean where it prevents you from reaching the desired camber. for example, if you are really low in the rear and you want to 0 out (straighten) your camber that arm in between is not long enough which will fight the upper camber kit arm from reaching that degree and cause to much tension which can lead to ride stiffness, stability, or something breaking. However, some can get away without changing this arm for their setup.
i did this so i can have full free mobility/alignment of my rear hub assembly so i can adjust it to wherever i please.
take a look at this image. this is from team mori's 3gs. fully adjustable hub assembly. this not the best picture because the arm in between the camber and toe links is being blocked by the lower control arm (which is also adjustable)
the front upper ball joint is to adjust your camber in the front. with this im able to go positive camber up to positive 1 deg and up to negative 3 degrees. however, the lower you go the closer it is to colliding with your strut tower because there is no room for your shock to travel and it will hit that frame area. this is why you would need to either get a shorter hub assembly from T demand which costs like 1500 or drill a hole in your frame for more travel. see image below.
i got my main upper camber arm from SPC along with the front ball joints. and the arms i got from Figs Engineering. the only thing im missing is the lower mega arm for full adjustabiility of my hub assembly. megan has them at a cheaper price but i have never had any good luck with their parts lasting on any of my cars which is why i chose SPC first, then any other company, then lastly megan (this is just my opinion, some people swear by megan but like i said i haven't had any luck with them).
