Window Regulator broke, Window fell inside door
Old Sep 24, 2013 | 07:53 AM
Bouncer's Avatar
Bouncer
Default Window Regulator broke, Window fell inside door
This is on my 1995 SC 400 Driver Door...
The window fell inside the door as I was putting the window up. A plastic piece broke. I did salvage one piece so far. Somehow I have to fix this because a new regulator and motor which come together says Lexus of Greenville, S.C. cost 776.00 at dealer cost through the dealer I work at.
I have seen a few ways to fix the plastic piece but those were more intact looking. I only found a partial piece so far. Going back in this week end and looking for more plastic pieces inside the door.
There is a plastic piece still under the regulator part with the flat surface that goes underneath the window. I am unsure where the broken piece came from. The motor moves the cable just a tad when I push or pull up on the power window button but seems jammed.
I can push the piece that is underneath the window up to close the window but seems like there is nothing holding it up. If I hit a bump, it will just fall to the bottom.
Looking for a better fix then 776.00. Thanks.....
Old Sep 24, 2013 | 04:08 PM
turbodremz's Avatar
turbodremz
Best way to start would be to post in the correct section. Build threads section is for, well just that...builds. (engine swaps, auto to manual swaps, f/i additions, etc.)
Next would be to message Aliga. I got my drivers regulator from him over 4 yrs ago, and mine is holding up strong. After you get the regulator, there is a DIY on how to make it last much longer for about $6.
O. L. T.
Oct 29, 2022 04:31 AM
kla002
Nov 3, 2012 05:42 PM
BostonSC4
Nov 28, 2010 05:42 PM
davidv433
NELOC
Feb 6, 2009 09:06 PM
1gs430
Sep 30, 2007 07:16 PM
