Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 06-28-17, 09:24 AM
  #1156
8052JZ
8052JZ's Avatar
Originally Posted by Blkexcoupe
That's good to know about the epoxy. I've seen too many bad results from DIY kits where the epoxy starts peeling from tire heat.
Does your lift require the cement to be a certain depth to safely anchor it?
Yes, I was also worried about the hot tire pickup but from reading that's the result of improper prep.
This lift is required to have a minimum of 4 - 4 1/2" 3000psi poured concrete. I think the standard thickness for garage concrete is 4". At least in my area.
Originally Posted by gerrb
Richard ... that lift will make working on your car so easy
Indeed it will. It will make things much easier for me. Cant wait to give it a try.
Originally Posted by 97-SC300
Wow man..... that garage! That is beautiful my friend.
Lots of work to do the epoxy floor properly. Lot's of prep, but boy o boy does it pay off at the end!
Shelving and tool boxes looking proper as well! Very well done!
Thank you! If I were to do it again, I may pay someone to install it but then again, I don't plan on dong it again lol. Its very labor intensive with how I wanted it done.
Very happy on how it turned out.
Old 06-28-17, 09:53 AM
  #1157
JasGS350
JasGS350's Avatar
Love that garage set up. It will definitely make working on your car more enjoyable.
Old 06-28-17, 10:34 AM
  #1158
LexIS007
LexIS007's Avatar
Very nice bro! My brother-in-law just did an almost exact garage setup as yours.
Having a lift in the garage is so key!
Old 06-28-17, 02:30 PM
  #1159
8052JZ
8052JZ's Avatar
Thanks! Now I just need to find the time to actually work on the car and get the first use out of the garage.
Old 06-29-17, 02:50 PM
  #1160
CatManD3W
CatManD3W's Avatar
Congrats man on the new house. That garage is looking pristine.
Old 07-03-17, 08:07 AM
  #1161
8052JZ
8052JZ's Avatar
Thanks man! Still have some work to do but its coming along nicely. Still have lights to wire up, work bench and welding table to make.
Old 07-03-17, 04:02 PM
  #1162
GTX580
GTX580's Avatar
NICE!!!! I am in the process of buying a 3 car garage house up north and plan to do this as well.
on a side note I want to get into powder coating, did you start out with a 30 inch oven? Also, which sand blaster would you recommend.
Old 07-05-17, 09:40 AM
  #1163
8052JZ
8052JZ's Avatar
Where up North? I'm in Buellton Ca, now.
I made my oven and sandblaster.. Works great for me with the small things I coat. Wheels are the most popular parts I do.
Old 08-08-17, 11:30 AM
  #1164
8052JZ
8052JZ's Avatar
Welp... my thread is another victim of the Photobucket link loss. Wish I had the time to re-post on those pics but that would take a very long time.
So now that photobucket is no longer a solutions to posting pics, I'm going to try another approach. I'm going to start making video's of my build which will cover how I do things along the way. I'm going to try my best to cover the progress of my build using video's clips rather pictures.
If you guys have any suggestions on how to go about this approach, let me know. I'm always open to different idea's. This first video isn't that great but I hope it gets better along the way.
Old 08-08-17, 02:25 PM
  #1165
gerrb
Super Moderator
gerrb's Avatar
Richard - does your -12an fuel feed to the Weldon that is welded at the bottom of the tank piped towards the inside of the tank's plastic swirl pot ... meaning , it is pumping fuel from the swirl pot ?
And where does the fitting on top of the tank for your return line go to ? also to the swirl pot or it is just dumping fuel inside the tank ?
Old 08-08-17, 02:44 PM
  #1166
8052JZ
8052JZ's Avatar
I did this so it functions just like factory. The factory pump feeds from sitting in the swirl pot and the return line from factory also dumps directly into the swirl pot keeping the pump always submerged and fed. So the feed pipe welded to the tank comes through the swirl spot on the side that's closer to the rear bumper. The fitting that's welded on top of the tank is a return tube that dumps fuel directly into the swirl pot.
Some pics attached.. defeats the purpose of the video haha but I noticed I didn't get a good pic of the inside after everything was said and done but you get the idea.
Attached Thumbnails 8052JZ's NA-T Build-img_8187.jpg   8052JZ's NA-T Build-img_8192.jpg   8052JZ's NA-T Build-img_8190.jpg   8052JZ's NA-T Build-img_8201.jpg
Old 08-08-17, 02:49 PM
  #1167
gerrb
Super Moderator
gerrb's Avatar
^^^ got you ... just trying to make sure .... that you don't get any fuel starvation
Old 08-09-17, 07:45 AM
  #1168
8052JZ
8052JZ's Avatar
lol thanks
Old 08-30-17, 08:43 AM
  #1169
Sc375
Sc375's Avatar
get it done already
Old 08-30-17, 11:31 AM
  #1170
8052JZ
8052JZ's Avatar
Originally Posted by Sc375
get it done already
Breerruhh.. I'm trying! You need to swing by so we can take care of that oil leak and get my car done lol
Quick Reply: 8052JZ's NA-T Build
