Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 12-14-13, 07:38 AM
  #436
gdoutlex
gdoutlex's Avatar
looking good bro, man i wish i had a welder also.
Old 12-14-13, 06:54 PM
  #437
8052JZ
8052JZ's Avatar
Thanks fellas. Hopefully tomorrow I can get her started for the first time again! We finished the down pipe and midpipe today and will be starting the rest tomorrow as well.
Sense the vibrant muffler is 5" OD, we decided its best to place it in the very back where the mufflers usually go. So ill
Be ordering another one of those mufflers for the rear. There's just not enough ground clearance with the 5" od muffler being under the car by the drive shaft and in front of the diff. Pics to follow later on!
Old 12-16-13, 08:12 AM
  #438
8052JZ
8052JZ's Avatar
So never got around to try and start the car this weekend. After the downpipe and midpipe where completely welded, the angle slightly changed so the midpipe had to be tweaked. Took me a while to figure out what to do but I fixed it and fitment is perfect now. Leveled out with the car and tucked up as much as it could.
My buddy with more experience did most of the welding
vband welds that I did
Old 12-16-13, 08:18 AM
  #439
jwin
jwin's Avatar
Looks bad ***.
Old 12-16-13, 08:19 AM
  #440
jwin
jwin's Avatar
Wish I could start my car. Waiting for the proefi sale. Might just go ahead or get a aem v2. Lol.
Old 12-16-13, 08:36 AM
  #441
8052JZ
8052JZ's Avatar
proefi ftw! its worth it but that's why I went with the v2 I already had everything wired for the v2 plus gauges and what not so that's why my decision was to stay AEM. Would have taken me longer to sell off the AEM things anyway.
Old 12-17-13, 09:21 AM
  #442
JesLet
JesLet's Avatar
Man i want those welding machine you have... I'd like to play with it instead paying someone to weld my stuff.
Old 12-17-13, 09:52 AM
  #443
8052JZ
8052JZ's Avatar
It is very handy to have! look on Craigslist they are always popping up for sale at a fair price. Diffidently makes things way easier having it. Makes anything possible.
Old 12-17-13, 10:11 AM
  #444
JesLet
JesLet's Avatar
What kind/model is the one you have? I need oxygen too right?
Old 12-17-13, 10:21 AM
  #445
8052JZ
8052JZ's Avatar
That's a Lincoln Precision 225 Tig using 100% argon Gas like most Tig welders do. The smaller bottle is for my Mig Welder that uses 75% argon 25% CO2. When we welded the the dp/mp we used the 75/25 mix for "back gassing" the stainless welds. This helps the welds to look like the outside welds with no splurge or what ever you want to call it and gives it a better over all weld.
Old 12-17-13, 01:56 PM
  #446
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Man, your welding skills are great. You ought to see my welding skills, well no you don't. LOL
Old 12-18-13, 07:45 AM
  #447
8052JZ
8052JZ's Avatar
Thanks I've only been tig welding..... oh...... maybe 2-3 months now lol Ive been mig welding much longer and after picking up the tig torch, I cant see my self going back to mig welding for projects like these.
Old 12-19-13, 08:00 AM
  #448
8052JZ
8052JZ's Avatar
I thought i would take a few shots of the midpip under the car this morning for you folks. The rear part of the midpipe is slanting down because its not supported yet. It will be level all the way across after everything is done.
I tucked the 4" up as close to the body as possible and I'm also going to look into putting some sort of heat barrier on the chassis to help heat oft it..
Old 12-19-13, 08:21 AM
  #449
JesLet
JesLet's Avatar
What kind of shims are those on the differential?
Old 12-19-13, 12:15 PM
  #450
8052JZ
8052JZ's Avatar
Those are solid ear diff mounts from FSmoto. These require to use the oem washer with the bolt
Quick Reply: 8052JZ's NA-T Build
