2jzGTE SCs - The Siblings of my Supra MKIV Toys
#1516
1JZ Single SC400
Man this thread is getting better each time I read the follow ups. You are on your way in becoming a tuner, I just know it. The red car just needs a good paint job and drive this thing. I want to see it making some pulls through the gears. The engine bay just looks incredible man. All those custom lines, fittings, and so on. Just a work of art.
#1517
True, the red mamba needs a good paint. Also I am still trying to replace some rubber lines in the engine bay with SS braided lines. Again I need the right fittings... never ending purchase of these freaking fittings. Like the rubber hose from the IACV to the intake manifold needs to be replaced. That hose is very important for my idle tune. The air being taken in by the IACV is being restricted along the way to the intake manifold. That messes up what the ECU is telling the IACV how much air to let in , then meanwhile same air is not being let into the intake manifold because of the hose collapsing . Suspension / Wheels and tires need work too to handle the power. Remember power without traction is useless .
Once l have replaced all rubber lines and cleaned up the engine bay , maybe I will try to repaint it again. I am considering of removing the Heater Control Valve to clean up a bit the bay. I wonder what will be the bad effect. Isn't that valve used to control the amount of hot water going through the heater core inside the cabin ? Anybody removed this and had bad effects ?
#1519
Didn't have to buy fittings for my IACV hose, am tired of buying fittings anyway, lol . I found a 3/8 npt barb fitting and a -10an in my pile of junk so I managed to replace the hose as soon as I arrived home from my tuning training today. Now that the intake manifold side of the SS braided hose is fastened , I will need the -10an male bung welded into the IACV flange.
#1524
Today , went to a welding shop that was operated by a father and son to get three pieces welded. They were aluminum parts so got to get someone else do it. One for my IACV , the other two for my AC system. It costs me $60 to get 3 small things aluminum welded which I believe was fair enough considering the time they spent on it.
#1528
I will take some for you in the morning buddy so you see how they are installed !
This is what I did ... our 1992 SCs do not have the freon refill port on the AC hard lines . It is on the compressor. So I had to take the AC hard lines from the SC300. I took out the end part coupler from our 92 that connects to the firewall and got it welded to the SC300 line that has the refill port.
Picture below shows the end part from the 1992 line has been cut already
As you can see on the next picture the end part is about to be welded
The rubber line connected to the compressor on the JZ engine has one of its end oriented 180 degrees so again I got that from the 92 SC400 and got it welded to the JZ rubber line end.
This was the end from the JZ line that I replaced with that of the 92 SC.
here you see the welded parts .. will take pictures for you tomorrow where they are installed buddy !
#1529
Here you go for the pictures of those welded parts installed .
first part bolted near the firewall . Now I have a freon refill port since I used that from an SC300.
second part bolted at the bottom going to the drier or condenser I believe (forgot to check) . That line goes to the compressor.
After taking those pictures , decided to drive the car around the block. My freaking idle is out of whack . so I had to modify my IDLE % vs TARGET RPM Map again. This just confirms the first cardinal rule before getting your car tuned. MAKE SURE YOUR CAR IS MECHANICALLY AND ELECTRICALLY SOUND and all your SENSORS are GOOD !
When I tuned my idle last week , I had a kink on the rubber hose from the intake to IACV as seen on the pictures before I replaced that rubber hose with SS braided hose. So the amount of air entering the engine through the IACV to make corrections on the IDLE RPM was messed up . Since I have replaced that hose, air is now free flowing coming from the IACV. Now after modifying the map, the IDLE % duty are even lower since there is no restriction . The idle is even better and engine a lot , lot quiter .. lopey cam sounds are even more distinct since you barely hear the intake of air from the IACV.
