Build Threads Details on Club Lexus LS460 owner vehicles
Dat intro and build thread
Old Jun 25, 2012 | 06:17 PM
  #46
Lextrician's Avatar
Lextrician
roll and a pull will do it. but you are going to rub on that insulation in there..
Old Jun 25, 2012 | 08:17 PM
  #47
Nat's Avatar
Nat
Can you do a roll and pull even though the fenders are shaved?
Old Jun 25, 2012 | 09:49 PM
  #48
PRSUIT460's Avatar
PRSUIT460
Wow that's a bummer.. Even if you get them to fit it will probably look weird from behind with that much tire sticking out..
Old Jun 25, 2012 | 11:53 PM
  #49
cheez80's Avatar
cheez80
don't pull the fender -- if there's enough clearance between the spokes and the caliper, shave the wheel hub
Old Jun 26, 2012 | 12:03 AM
  #50
lbintab's Avatar
lbintab
It doesn't look like its shaved flat. He can still roll a little and pulling is easier when it's shaved. Less chance of wrinkling the fender. I would pull but if he's not willing to that then maybe putting in more camber. I just don't know how adjustable it is.
Old Jun 26, 2012 | 05:38 AM
  #51
Lextrician's Avatar
Lextrician
depending on how much material is on the hub will tell u if you can shave it or not and be safe.. are those multipiece??? if so smaller lip will do it, much cheaper than a two new rears wheels similiar situation with me but i had to buy two new barrels for the fronts!! i would have the body shop roll em and see what extra clearance there is but you definitely need some camber... sucks but not impossible..
Old Jun 26, 2012 | 05:45 AM
  #52
datplayaz's Avatar
datplayaz
I didn't shave the fender super close there might be 1-2mm left in there, but even if I sand it smooth, it still wont clear, I'm not willing to pull the fender cause I don't want to change the body line at all. Putting more negative camber is a great idea, but not a option because the cambers on these cars are not adjustable. I might go with Cheez80 idea and shave the wheel hub, but I'd have to look into that more to see if it's safe.
Old Jun 26, 2012 | 09:16 AM
  #53
lbintab's Avatar
lbintab
There was a thread on here where a guy said he put in more camber in to his rear suspension to get his wheels to fit. He said it was custom work but never really said how.
Old Jun 26, 2012 | 10:20 AM
  #54
datplayaz's Avatar
datplayaz
If you're talking about the camber work that Platinum VIP did, I already contacted them and they said they would need the car to be at their shop and I'm in a different state.
Old Jun 26, 2012 | 10:52 AM
  #55
cheez80's Avatar
cheez80
not going to expose any secrets but their method isn't the best for your car. shave the wheel hub or get smaller outers
Old Jun 27, 2012 | 11:31 AM
  #56
datplayaz's Avatar
datplayaz
So after talking to Tong over at VIP Modulars, we figured out why my wheels didn't clear. They mixed up the faces while assembling the wheel, the front face was on the back wheel and the back was on the front, now I just need to unbolt them and switch them.
Old Jun 27, 2012 | 01:24 PM
  #57
lbintab's Avatar
lbintab
Makes total sense. That should bring it in just enough
Old Jun 27, 2012 | 03:38 PM
  #58
Lextrician's Avatar
Lextrician
even better if they are 3 piece dont break that seal if they are 2 piece then your good easy swap but 160 bolts take a while!!!
Old Jun 27, 2012 | 03:41 PM
  #59
datplayaz's Avatar
datplayaz
Yeah hopefully I don't break the seal, I'm not looking forward to switching them and going through the 160 bolts lol.
Old Jun 27, 2012 | 03:54 PM
  #60
brianlin87's Avatar
brianlin87
is shipping the wheels back to them to get it right out of the question? I wouldn't want to be spending my time sitting there and doing the work that someone else should have done.
