Bead Maker...! or ...?
#31
On the next wash of the wife's ride, I'll be applying BSD on one side of the hood and BM on the other. It's black so the differences should be apparent. Tell me... would IPA remove the existing BM and the Blackfire One Step AIO I applied a few weeks ago? If so, is there a particular type or concentration I should purchase, or would any bottle from Walgreens do?
#32
What I'd recommend would be an aggressive touch wash (scrubbing the paint with car soap and a wash mitt in the area(s) to be tested at the minimum), rinse and drying, followed with a clay bar and then the IPA wipe down so you know 100% you've removed all protection, embedded particles and contaminates (the only extra step would be a decon type of soap to remove ferrous metals while doing your aforementioned touch wash). At this point you're down to the bare clear coat. You've now removed any chance of something else interacting with the spray on coating and have leveled the playing field for your product comparison. I presume that's your goal here? Keep in mind as you layer product(s) there's always the chance of interaction between the layers of applied products.
AG has a great write up on IPA use and concentrations, **NOTE** most people use way to strong of an IPA solution that could potentially damage the clear coat, this is one of those times when if 1 is good, 2 is better thought process can actually cause unintended harm. I'd rather do two (2) wipe downs with a weaker IPA dilution than 1 with to strong of a mix.
https://www.autogeekonline.net/forum...n-results.html
I always do the IPA after the clay'ing process as clay does very slight mechanical damage to the finish as it removes the embedded contaminates, but the clay lube spray does put a small amount of protection on the surface being clay'd. The IPA will also remove all the residual clay bar that may be left on the surface, which there's always a little bit left no matter how much lube is used.
Isopropyl Alcohol at any store will work just fine. You're not needing reagent grade, any off the shelf 70% will work just fine.
#34
That's been about my take on BM so far.
for:
- Ease of application
- Best slick feeling in the industry
- Shine and Gloss Enhancer
- Easiest quick detailer ever
for:
- Much less beading that the competition, even less performance than products that cost much less, like Meguiar's and Turtle Wax spray waxes and detailers
- Under-par hydrophobic qualities on paint
- Water spotting is evident on paint; never noticed water spotting on my Liquid Platinum before using BM
- Under-par hydrophobic qualities on glass; Rain X is by far a superior product; it rained this past weekend and BM on my windshield was a disappointment, I wanted to stop and apply Rain X
- Dust, dust and more dust, after a week or more, the build up of dust is unbelievable
- Grime build up. Haven't yet determined if it attracts this oily film I see on the surface causing the dust to stick, or if the environmental conditions are causing the BM to "turn into" this oily film... heat and humidity of South Florida perhaps?
I haven't done my intended side by side experiment of BM and BSD yet (out of town this week), so I'll start that this weekend. Like my son has told me... above is my hypothesis, the experiment will either support or refute my beliefs.
But now... what about this line of Nova products? Especially the Jet and Boost...? Interesting stuff!
for:
for:
#35
for:
for:
for:
for:
I'm seeing more and more my original feeling that BM is really just overpriced, over-hyped detail spray in a container.
#36
I'm on my second bottle of Bead Maker and have cooled off on my enthusiasm for it. It works fine (except for some really visible streaking when I used a quick detailer on top of it) but I don't think it's any better than my other go to spray waxes and detailers. I'm not sure if I'll keep using it. The hype and buzz on BM has been impressive though.
#37
#38
Turtle Wax Seal N Shine is better and much cheaper.
#40
No product is a "magic" product. I don't have any issues with "oily film" or grime buildup. Dust attraction seems typical to me. I use it as a QD, it has great gloss and slickness...it never streaks...what more would one want from a QD?
Overpriced? I think I spent $40 for a gallon?
#41
I look at BM like everything else... it won't please everyone, but it will please some. It's just not turning out to be the best product for me...
I still have more than half a gallon, so I'm trying to figure out the best way to utilize what I have left, other than relegating it solely to the wife's company car.
#42
The issue I have is the shilling and hype of the uTube guys that claim it's the 2nd coming of Christ in a bottle.
#43
But I think the product leaves a slicker, glossier surface than any of those products, and I don't have to mix it like I would Detail Juice or ONR used as a QD. Cost per use isn't something I even consider.
I think your issue with it is like you said more tied to the hype than the product itself.
#44
#45
I also prefer concentrated products for space purposes. I can easily add my own distilled H2O, I don't need a company to do that for me and charge a premium. It also allows me to vary my concentration(s) or use the product as an additive, which I do quite often.
