Will steam cleaning the engine damage it?
I know there's a lot of debates to this, but if done properly (i.e. not getting moisture into vulnerable electronics, accidentally disconnecting hoses, etc.) does it really damage the engine in some other way? I know the alternator gets wet all the time (from driving in the rain), so spraying water into it isn't going to do damage (correct me if I'm wrong). What about chemicals degrading parts of the engine?
I use Meguiars super degreaser (lightest dilution) in engine bay with success, various microfiber, wet/dry vacuum, and steam to clean engine. It doesn't have to be 100%, even 10-15 minutes spent you can make a huge difference. The problem at least for me with using open water in the bay is that this engine bay has quite a few electronics and wiring so using running water and adding risk for having a clean engine bay wasn't worth it for me. I'm not saying it can't be done, however I just didn't feel comfortable with splashing water all over the bay things can get quite pricey with this car. You can get far with steam, wet/dry vac, microfiber, degreasers, and a little love!
k20trick (05-12-17)
dinhNER
Automotive Care & Detailing
07-21-06 08:12 PM
xknowonex
07-19-05 09:46 PM
