Best Wax for Black car?
#31
"Also, GLARE®Plus + PROFESSIONAL POLISH creates a paint surface so smooth and slick that the Air-Drag Coefficient of your vehicle will be significantly reduced, actually making your vehicle more aerodynamic."
Legit products do not need to make such outlandish claims. I've not read hype like that on the sites of say, Car Pro, Optimum, 22PLE, Gtechniq, etc.
#32
Auto Detailing Master
A good rule of thumb in the detailing world is to use what is tried and true... there are TONS of smaller companies like this that survive by luring in customers with their fancy marketing and wild claims. The truth of the matter is that if something is really "that good" it usually catches on and grows like wildfire.
Companies like Meguiar's, Optimum, Menznera, CarPro... they didn't just start as big, well known brands. They've evolved from small business to industry leaders for a reason.
Now sure there are unknown products that are probably great... but for the majority of people, it's just going to be a better experience if you stick to the known brands and products as they have proven their worth over and over again.
Just my opinion
-zach
Just my opinion
-zach
#34
Just because I like to "pile on" (they mention Boeing and application to aircraft on their FAQ page):
From http://flightshield.com/docs/Boeing%20Report.pdf:
and
As a result of these studies, Boeing has
concluded that the finished skins on Boeing
commercial airplanes, both aluminum and
composite, are essentially hydraulically
smooth. The equivalent sand grain rough ness
of the skins of Boeing airplanes is typically
less than 400 microinches. As a result,
very little additional roughness drag can be
assessed beyond normal skin friction dom-
inated by turbulence in the boundary layer
(see fig.!3). These studies concluded that
additional coatings would not materially
reduce the turbulent flow skin friction drag.
Boeing research supports the conclusion
that use of external surface finish coatings
should be based on surface protection
properties and airplane cleanliness, not drag
reduction. There is no plausible engineering
explanation to justify a drag reduction
beyond approximately 0.1!per cent, nor is
there conclusive test data. Boeing wind
tunnel data confirm that the production
surface finish of Boeing com mercial air-
planes are hydraulically smooth, meaning
that further surface smoothness would not
result in a measurable drag reduction.
#35
Just my opinion
-zach
Just my opinion
-zach
#36
I figured out why I was getting wheel marks on my 14 RX Stargazer. I was moving the buffer too fast across the panels. By moving it too fast it wasn't allowing me to work the polish into the paint.
Now that I've moved it slower the results are outstanding. I can't say the Glare product is the best but, I couldn't be happier with the results.
#37
-Zach
#39
Meguair's Black Wax
I just tried Meguiar's Black Wax and was impressed with how shiny it made my black car. It was relatively easy to apply/remove & smells nice; altho it does haze & leaves a residue if not removed completely. Added bonus was that it covered up a fair amount of swirl marks.
For a fairly cheap ($8.99 on Amazon & Wal-Mart) and easy to find product, I highly recommend. it.
#40
The best is very subjective. You will find many professional detailers who all have their go to products and you have hobbyists detailers who have a million different opinions. You can get a wax that has many fillers and makes your car look really good for one to two washes until the fillers wash out of the swirled paint.
OR
You can learn how to properly take care of your paint and reduce the amount of swirls, rids and scratches into your clear coat.
If you want to dive into this world of car care learn the basics. One good sight is autogeek.com. Knowledge is key to maintaining a black car! There are other sights on the internet but this one has a really good forum & lots of helpful people.
What you need if you don't already have them:
2 bucket system & grit guards
Boars hair brushes, one big one for the body and the wheel one.
Barrel brush for getting behind the spokes
Small boars hair brush for getting in tight cracks and nooks.
Dual action machine
Back plate
Wide variety of pads (recommend 5.5")
Variety of products ($$$$$) polishing, compounding & waxes, sealers, trim care, metal polishes for your exhaust tips.
Interior care
Leather cleaner, leather conditioner, mild detergent for interior trim and any spills, boars hair brush for dusting off dash and AC vents. I keep mine in the center console and get it out when I'm waiting for someone and dust off the interior quickly.
Total cost for a good all around starter kit is about $1,100.
You'll also need good lighting because you can't detail what you can't see. So add in some 500-1500watt halogen work lights. Some guys use special lights that work well to mimic sunlight and help show rids/scratches while they are working. I'll have to admit I'm one of them. Once again you can't fix what you can't see. Also get yourself some ear plugs because operating a DA polisher for 10+ hours a day gets noisy. Some knee pads or a gardening foam pad works well when working on your knees to get the body from mid-door down.
There are two types of black cars.
A. The best looking car in the parking lot
B. The ugliest car in the parking lot.
It all comes down to how the owner cares for the vehicle. It will either make you or break you. With a black car there's no Inbetween. The cars paint will show off any and all imperfections.
Good luck!
OR
Dual action machine
Back plate
Interior care
Good luck!
#41
I like Rejex, it's a sealant, not a wax. I use it on my car 2-3 times a year. It will outlast the wax and provides awesome shine.
Make sure you wash and clay bar your paint before applying. Best times are early morning or early evening.
#42
I like the sealant over wax. It wears down way too fast. But the sealant and wax combo looks amazing. I am using Cquartz and wax on top. Brings out a nice deep dark in depth color.
