Foam Gun?
New here and trying searching but couldnt find anything. Does anybody use a foam gun for washing? Just wondering the pros and cons of using one. I am thinking about getting one to keep my baby clean.
Moved your thread to the detailing forum where there are a few foam gun threads
Some links for you to start with
https://www.clublexus.com/forums/aut...highlight=foam
its a great tool.
pros - you save time
you can save a bucket (instead of the 2 bucket method you can use the foam gun for the soap and 1 bucket for rinse)
you will have a ton of fun
cons - you will use a bit of soap.
I love my DI Packages Foamaster II Advanced Kit (aka foam gun) to help wash my car. I use it to pre-soak the paint which loosen and softens contaminants on the surface. Since most swirls come from the washing process it's critical to use good technique and products and this unit helps quite a bit in this area in my opinion. It also saves me a little bit of time during my washing process. The downside as mentioned above is that I do use more shampoo. I'd recommend spending twenty+ $ on a gallon of shampoo like the Chemical Guys Maxi Suds II or the Chemical Guys Citrus Wash & Gloss if you wash semi-regularly. Don't forget you can save 10% off all these items with your Club Lexus discount code "10offcl". If you have any questions please let me know.
Greg
Greg
Thanks gregg. I already ordered some of your maxi suds II for washing and love it. I ordered it because i saw i can use it in the foam gun which i planned on getting sometime. Just didnt think it would be this soon (ordered like 2 weeks ago). Also what would you recommend for wax. Right now i am using mothers gold canuva wax. I like the way it beads. Anybody else have anything else they like or dont like about the mothers?
If you prefer a wax try the Chemical Guys 50/50 Limited Series Concourse Paste Wax which is one of my very favorite waxes. If you want an amazing shine with a great value try the Poorboy's World Natty's Blue Paste Wax.
Don't forget to save 10% with your forum discount code "10offCL". If you have any questions please let me know I'd be happy to help.
Greg @ DI
I do have a few questions since this thread since its already started...
Thinking of getting the Foam gun as well.... How long do i pre-soak the car for? also after time has elapse lets say 10min then i do a rinse with regular water? Then wash the car by hand with Mcquires or any car soap correct. Do i still use the two bucket method? I've always wanted to get this just never new how to properly apply it.
Is it best to also a pressure washer in the 1200-to 1500psi range? or just attach the Foam Gun to the hose?
Seems like contaminants would come off easier with the pressure washer.
Just want to make sure that we don't wash the car while the suds are still on the car. That can cause scratches with the loose contaminants on the car...
I always do the 2 bucket method but thats not always 100% scratch proof. I think your bound to get minor imperfections from washing. Its human nature...
Thanks
Edit: Found this comment on DI's website...
Working in the shade to start, use 1 ounce of CG Citrus Wash & Gloss and a few ounces of water. This is plenty to produce enough suds to do a thorough 2-stage washing. The suds really help to emulsify and loosen the dirt on the vehicle.
STAGE 1: Spray suds on the car, then wait 7 or 8 minutes, and rinse.
STAGE 2: Then, reattach the foam gun and spray suds on the car again and switch over to the two bucket method to complete the washing.
Then final rinse and dry with a quality waffle-weave towel.
So my question is this guy rinsed after 8 min then reapplied the suds again for his two bucket method. Would you use the Citris wash to scrub the car?
Thanks
Any kind of wash will do. I use cheap, sudsy soap for the initial and during foam process anyway. I found CG Citruswash and Clear to be lacking in cleaning in my opinion. Even with a chemically cleared nozzle, the foam generated depended on a lot of soap. I use a 1750psi unit
Sam's club had a nice electric pressure washer last time i was there for like $60-$70...
Thanks Isaac...
Yep, foam guns are great! Apart from being the most fun part of washing your car, it pre-soaks and breaks down the dirt and grime with out you touching your car. That equals less wash swirls. And buy one from UK and save lots of $$$!
So using a low pressure washer like that is ok? I certainly like the idea of leaving the suds on there for 8-10 min. rinse, and then doing the 2 bucket method, I have the Citriswash just never used it it..
Thanks Isaac...
Thanks Isaac...
