Where to get O-Ring Gasket?
Old May 15, 2011 | 04:17 PM
pchan0's Avatar
pchan0
Default Where to get O-Ring Gasket?
Just purchased a used Lexus exhaust, previous user used 'epoxy' to seal both of the mid-pipe flanged ends and I did not see any O-Ring gasket. Any one know the part number for the O-Ring? Or where can I get it? I'm in CANADA!
Also about the M10 bolts and M10 nuts, can I use any kind that I can find at a local hardware store? Or are these bolts heat treated, high strength or whatever?
THANKS!
Old May 15, 2011 | 07:23 PM
anthrax144's Avatar
anthrax144
Sewell sells them:
http://is.sewellparts.com/oem-catalo...S350-2006.html
Kind of pricey though for a gasket - $28.72 with CL discount. They also sell the bolts and nuts.
Old May 19, 2011 | 09:57 AM
pchan0's Avatar
pchan0
Can't find the o-ring gasket for the mid pipe flanged ends on sewell, any help?
Old May 19, 2011 | 10:23 AM
Joe Z's Avatar
Joe Z
Lightbulb
Ok so you don't mean the large donut gasket that connects the mid-pipe resonator to the rear axle exhaust flange ??
You need the the two gaskets that connect the F-Sport / Lexus HKS axle piping sections seen here:
I would call up Sewell, and see if they can put together a "Service Parts Kit" for the F-Sport Exhaust...
That way you can get all new (properly designed) F-Sport hardware and gaskets for your install.
Do it once & do it right..
Regards,
Joe Z
Old May 19, 2011 | 01:25 PM
Laid_Out's Avatar
Laid_Out
Originally Posted by anthrax144
Sewell sells them:
I think that's the going rate for gaskets these days. I wouldn't think they'd be so pricey but I was surprised when I had to replace mine when I had a 350z a few years back
Old May 24, 2011 | 02:55 PM
pchan0's Avatar
pchan0
Regards,
Joe Z
Darrel at Sewell came through with the o-ring 'package', but I still need to find the part numbers for the 4x M10 bolts, washers and nuts. Any ideas?
Thanks!
Old May 31, 2011 | 05:08 PM
Laid_Out's Avatar
Laid_Out
You should be able to get them at any hardware store but get a high grade like 8 or higher. Make sure you don't mix fine thread and regular.
Old Jun 6, 2011 | 03:30 PM
pchan0's Avatar
pchan0
Are these the O-ring gaskets that you got with the F-Sport exhaust? They are silver in color!
Old Sep 8, 2011 | 02:37 PM
kais250's Avatar
kais250
Hi, where did you end up buying the M10 bolts and what size were they? I just purchased a used Greddy SE and it didnt come with the M10 bolts.
Sherl
12
Sep 18, 2019 11:54 AM
vkriss
Mar 15, 2019 10:30 AM
airjordan1
Performance
Jul 2, 2017 11:27 PM
qewani1
Jan 25, 2010 04:01 PM
yalavarthy
RX - 1st Gen (1999-2003)
May 4, 2005 07:56 AM
