List of TSIB (Recalls/Campaigns) for 3GS
Old Apr 27, 2010 | 06:49 PM
charmz's Avatar
charmz
Default List of TSIB (Recalls/Campaigns) for 3GS
This is a list for 06 GS300 AWD, but im sure at least some must also apply to the 350's and RWD models.
Thought this might be useful to some people? Maybe it would be helpful if anyone has the pdf's to any of these to post them in this thread and make it a sticky possibly?
Edit: Thanks to TWong350 for stepping it up for everyone here! BUT if you do recieve a TSIB from him PLZ UPLOAD IT IN THIS THREAD like I have done below so his inbox is not flooded with constant requests.
TSB Number & Issue Date - TSB Title
SSC9LA JAN 09 Recall - Fuel Rail Replacement
SSC7LC NOV 07 Recall - Fuel Pipe Replacement
SSC6LC APR 06 Recall - Front Seat Belt Retractor Replacement
SSC6LB APR 06 Recall - Side/Knee Air Bag Replacement
SSC9LC JAN 09 Campaign - EPS Steering Gear Replacement
SSC9LB JAN 09 Campaign - Rear Brake Caliper Inspection
SSC6LE JUL 06 Campaign - Electric Power Steering (EPS) Replacement
SB0188-09 DEC 09 Engine Controls - A/F And O2 Sensor Identification
SB0168-09 NOV 09 Fuel System - MIL ON/DTC's P0441/P0455/P0456
SB0085-08R1 OCT 09 Engine - Serial Number Locations/Identification
SB0084-08R1 OCT 09 A/T Serial Number Identification/Locations
SB0153-08R1 OCT 09 A/T - Reman A/T Serial Number Location/Identification
SB0092-09 AUG 09 Engine Controls - MIL ON/Multiple DTCs Set
SB0090-09 AUG 09 Audio System - Satellite Radio Inop Until Ign. Is Cycled
SB0076-09 JUL 09 Engine Controls - MIL ON/DTC's P0751/P 2714/P0894
SB0154-08R1 MAY 09 Tires - Pressure Compensation/Adjustment
CRIB173 APR 09 Paint - Refinishing Information
SB0025-09 MAR 09 Tire Monitor System - 'Lost Communication With ECU'
SB0023-09 MAR 09 A/T - Fluid Level Inspection/Temperature Ranges
CRIB172 MAR 09 Body - Bumper Component Repair
SB0011-09 FEB 09 A/C - Intermittent Unpleasant Odors
SB0001-09 JAN 09 Body - Moonroof Auto-Close Function Inoperative
SB0174-08 DEC 08 Steering/Suspension - Vehicle Pull Repair Supplement
SB0152-08 OCT 08 Engine - Brief Knock/Rattle On Cold Start Up
SB0125-08 OCT 08 Cruise Control - Check PCS Message/DTC B2056/P1572
CRIB170 OCT 08 Body - Plastic Bumper Refinishing
SB0123-08 OCT 08 Body - Trunk Won't Open Electrically/DTC B2216 Set
SB0120-08 SEP 08 Body - Fuel Door Loose/Difficult To Close
SB0091-08R SEP 08 Engine - Valve Timing Procedure
SB0090-08 SEP 08 Body - Upper/Lower Windshield Tick Noise
SB0087-08 SEP 08 Engine - MIL ON/DTC's P0300 - P0306 Set
CRIB164 SEP 08 Vehicle - Replacement VIN Plates/Certification Labels
SB0083-08 AUG 08 Body/Frame - Protective Wax Coating Information
SB0047-08 JUL 08 Lighting - HID Headlamp Diagnostic Tips
SB0040-08 JUL 08 Interior - Instrument Panel Rattle
SB0038-08 JUL 08 Interior - B-Pillar Lower Moulding Scratched/Gouged
CRIB167 JUL 08 Body/Interior - Trim Removal & Installation
SB0036-08 JUN 08 Keyless Entry - Smart Key Battery Diagnostics
SB0031-08 JUN 08 A/C - Interior (Cabin) Filter Replacement
SB0026-08 MAY 08 A/T, M/T - Alignment Pin Service Precaution
SB0024-08 APR 08 Brakes - Rattle From Vehicle Rear on Bumps
SB0021-08 APR 08 Engine - Cylinder Head Cover Baffle Precautions
SB0015-08 MAR 08 ABS/TCS - Zero Point Calibration Information
CRIB165 MAR 08 Body - Acid Rain Paint Damage Prevention/Repair
AC003R-07 FEB 08 A/C - Driver/Passenger Front/Rear Carpets Wet
CRIB162 FEB 08 Body - Quarter Panel Service Part Modification
CRIB163 FEB 08 Body/Frame - Sealing Hem-Flanges & Body Seams
CRIB161 JAN 08 Body/Frame - Collision Damage Repair Precautions
CRIB160 DEC 07 Restraints - SRS Service Precations
PG007-07 NOV 07 Vehicle - Replacement VIN Plate Information
CRIB158 OCT 07 Body/Frame - Panel Adhesive Information
SS006-07 AUG 07 Electrical - Absorbed Glass Mat (AGM Battery Info
SS005-07 AUG 07 Restraints - SRS Component Disposal
CRIB155 AUG 07 Body/Frame - Sectioning Guidelines
CRIB156 AUG 07 Electrical - SRS and HV Wiring Repairs
TC008-07 JUN 07 A/T - 'World Standard' Fluid Information
EG015-07 JUN 07 Engine Controls - Bank 1/Bank 2 O2 Sensor Identification
NV007-07 JUN 07 Interior - Inside Mirror Vibrates
BO006R-06 MAY 07 Body - Rear Power Sunshade Won't Open Fully
PG001-07 MAR 07 Tire Monitor System - Diagnostic Tips
EG003-07 MAR 07 Cooling System - Leaks From Water Outlet Assembly
EL001R-06 MAR 07 Smart Key(R) - Repair Manual Supplement
TC002-07 MAR 07 Drivetrain - Driveshaft Replacement Precautions
EG001-07 FEB 07 Engine - Timing Cover/Camshaft Housing OIl Leaks
EL002-07 FEB 07 Air Bag System - Repair Manual Supplement
EL016-06 DEC 06 Starting System - Vehicle Start After Battery Depletion
EL015-06 DEC 06 'Smart Key' (R) - Specifications
PG001R-06 NOV 06 Battery Maintenance for In-Stock Vehicles
SU001-06 OCT 06 Suspension - Shock Absorber Replacement Criteria
EG014-06 JUN 06 Emissions - MIL ON/DTC's P043E/P043F/P2401/P2402/
AU001R-05 JUN 06 Audio System - Dash Speaker Connector Rattles
NV001-06 MAY 06 Interior - Front Seat Squeaking Noise
EG011-06 MAY 06 Exhaust System - Excessive Sulfur Odors
AX001-06 MAY 06 Audio System - SIRIUS(R) Radio Antenna Separation
AU001-06 APR 06 Audio System - Quick Reference Troubleshooting Guide
EG006-06 MAR 06 Engine Lubrication - ILSAC GF-4 Oil Recommendation
BO002R-06 MAR 06 Body/Lighting - Headlamp Support Bracket Installation
PD023-06 MAR 06 Parking Assist System - Initialization Procedure
EG001R-06 JAN 06 Engine - ILSAC GF-4 Engine Oil Standard
BO001-06 JAN 06 Body - Trunk Will Not Close
SS003-05 NOV 05 Audio System - CD Player Skip Verification
EG020-05 NOV 05 Engine Controls - MIL ON/DTC's P0171/P0174/P02195/
BO012-05 NOV 05 Interior/SRS - Seat Cover Replacement
BO010-05 OCT 05 Restraints - Seat Belt Extenders Available
CRIB150 OCT 05 Paint - Paint Codes
BO008-05 SEP 05 Body - Left Rear Door Lock Difficult to Operate
NV002-05 SEP 05 Body - Creaking Noise from Back Glass Area
SS005R-01 AUG 05 Antitheft - Diagnostic Tester Immobilizer Function
BO007-05 AUG 05 Interior - Glove Box Doesn't Open
BO006-05 AUG 05 Interior/Lighting - Dome Lamp Comes Loose
TC003-05 AUG 05 A/T - A760H Solenoid Identification
PG007-05 AUG 05 Tire Pressure Monitor - Sensor Registration/Initializing
PG005-05 JUL 05 Tire Monitor System - Tire Dismounting Procedures
BO004-05 JUL 05 Wipers/Washers - Wiper Blade Cleaning/Maintenance
EG012R-04 JUN 05 Engine Controls - Entering VIN After PCM Replacement
SU001-05 JUN 05 Suspension - Creaking Noise From Front Suspension
EL006-05 MAY 05 Electrical - Vehicle Start After Battery Depletion
BO003-05 APR 05 Restraints - Seat Belt Extender Availability
PD008-05 FEB 05 Tire Pressure Monitor - Sensor Activation
PD007-05 JAN 05 Body - Power Window Initialization Procedure
PD003-05 JAN 05 Body - Sliding Roof Initialization Procedure
PD004-05 JAN 05 Interior - Driver's Head Restraint Initialization
PD001-05 JAN 05 Instruments - Compass Calibration Procedure
Old Apr 27, 2010 | 08:25 PM
TWong350's Avatar
TWong350
CL Folding 10,000
There are a total of 121 TSIB's for the 2006 GS300. There are 135 TSIB's for the GS350 model (all years). I can access any of these but getting all of these to PDF and uploading would be a huge effort. If someone wants a particular TSIB, feel free to PM me and I'll get you the PDF.
Note: Keep in mind that many of these aren't truly TSIB to solve issues. Some are tips and how-to's for things such as Pre-Delivery Service, etc.
Edit: For all of you that have PMed me for TSIB's, please provide me with your email address so that I can send the PDF's to you. I cannot send an attachment via PM. Additionally, before you email me requesting a TSIB, please do some research on this forum to search for what you need before requesting from me.
Old Apr 28, 2010 | 01:59 PM
charmz's Avatar
charmz
Default SSC6LE JUL 06 Campaign - Electric Power Steering (EPS) Replacement
File Type: pdf
Old Apr 28, 2010 | 02:00 PM
charmz's Avatar
charmz
Default SB0040-08 JUL 08 Interior - Instrument Panel Rattle
File Type: pdf
Old Apr 28, 2010 | 08:35 PM
GS350Lexus's Avatar
GS350Lexus
This is so very usefull stuff dude thanks a lot. Those pdf file's looking awesome if everyone one of those TSIB can be like that would be even better.
Old Nov 5, 2010 | 10:01 AM
helpmeout1's Avatar
helpmeout1
L-SB-0030-10 Intermittently Runs Rough
L-SB-0087-08 GS300 Valve Springs
L-SB-0038-08 B-Pillar Lower Garnish Damaged
NV001-06 FRONT SEAT SQUEAK NOISE
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 5, 2010 | 10:10 AM
helpmeout1's Avatar
helpmeout1
L-SB-0087-08 GS300 Valve Springs - Failed to upload. Too big?
NV004-06 INSTRUMENT PANEL RATTLE
NV005-06 UPPER/LOWER WINDSHIELD TICK NOISE
NV007-07 INNER REAR VIEW MIRROR VIBRATION
SU001-06 SHOCK ABSORBER REPLACEMENT CRITERIA
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 5, 2010 | 10:14 AM
helpmeout1's Avatar
helpmeout1
L-CP-ALE-A520-D -Valve Spring Recall (PART 1)
L-CP-ALE-A520-D -Valve Spring Recall (PART 2)
Old Nov 5, 2010 | 08:02 PM
kevinclee's Avatar
kevinclee
They are really helpful. Can you please post the PDF for the following TSIB?
SB0015-09R1 APR 09 Brakes - Front Brake Squeal/Squeak In Cold Weather
SB0155-09 NOV 09 Brakes - Excessive Brake Dust On Front Wheels
Thank you very much.
Old Nov 5, 2010 | 08:10 PM
BinaryJay's Avatar
BinaryJay
Looking for the new master cylinder recall document, for any of the affected vehicles (procedure probably identical).
Old Dec 8, 2010 | 06:12 PM
rockyk's Avatar
rockyk
Default SB0025-09 "lost communication with ECU"?
Can you please post or PDF "SB0025-09" the "lost communication with ECU" Service Bulletin for the tire pressure monitor system? Thanks much!
Old Dec 8, 2010 | 06:14 PM
rockyk's Avatar
rockyk
Default Sb0025-09
RE SB0025-09, my email is Rockykimball@comcast.net
Thanks again!
Old Dec 8, 2010 | 07:36 PM
BinaryJay's Avatar
BinaryJay
Thanks again!
That's not a PM. Better prepare yourself for an influx of spam posting your email like that on a forum for the crawlers.
Old Feb 23, 2011 | 02:26 PM
bhuwan's Avatar
bhuwan
This is great stuff. I do hae a question: how do you approach the dealer to apply some of these TSIB's? Do people just ask?
Old Mar 2, 2011 | 01:36 AM
nGeee's Avatar
nGeee
good find, this should really help all the 3gs out there
