Welcome to Club Lexus. Please take a look at the 2IS FAQ thread stickied at the top of this forum - this has many of the answers that are repeatedly asked (and answered).
When the battery is disconnected, the power windows must be initialized in order to ensure proper operation.
here is what to do in simple terms:
1. open driver side front window halfway
2. close driver side front window and hold switch for 1 second
3. have a look at the other door window switches (they should be flashing)
4. repeat same procedure with other 3 window switches
What about rear view mirrors----ever since I disconnected the battery to install the Ipod adapter now my side mirrors will not loook down in reverse. I did manage to get the windows and sunroof to work just fine, but not these.
any ideas?
Look to see if the mirror selector, the 3 way switch that is either L, none, or R is in the middle position, if so that's why it won't work. If you have it set to either L or R then it will work again.
Hey guys, I know that there is a process for resetting the window but I thought that it is only when the windows dont work at all. I have only the driver door working up and down with none of the other windows working from the driver switch or the window switches on the doors. I just wondered as the car was disassembled without the battery if any one has had this problem before?
Next time try taking a look at the stickied FAQ/DIY thread. It contains this link answering that question, which might well be the most frequently asked question in this forum.
This will happen every time you disconnect the battery terminal(s).
Follow the very helpful steps in this thread for resetting each switch.
If that doesn't work, make sure your child window lock button on the master switch is NOT pushed down..
***As that will prevent you from resetting the switches.
roll them down half way using the switch on each door. and then on the roll up hold it till you hear a beep sound than the windows with work from the drivers controls. i was freaked out by this too.
