CA FS: Exotic Air Cup Suspension
Hello,
I'm finally selling my air cup kit. It looks like the route I'm going with for my new car wont work with these cups. I'm willing to sell them for 1500 including shipping but I'm also willing to hear your best offer but the buyer will need to pay for shipping. Originally the cup kit cost 3500 not including additional 5 gallon in which it cost me 250. The kit is in working condition when I removed it. It will come with the 2 cup cylinders, 5 gallon tank, small tank, and VAir compressor. The only think that is missing are the lines and fittings in which you can buy anywhere.
Just as long its not an inverted shock and has good springs around 8k or higher should be good. if lower rate it might not raise up because the spring is to weak and it will just comprise the spring due to the wight of the car going up.
I don't think these will fit ANY coilovers. You will need to check the shaft diameter to make sure it will fit through the hole at the top. I think these are the knock off of Platinum VIP cup kit, make sure you measure your coilover before making purchase.
13FSPORT (02-22-17)
All cup designs have the same diameter. So these cups will fit KW, RSR, HKS, and so on. I know this because I have installed them in both my RSR and KW suspension. Also Platinum is not the original company that made cups. They and all the other companies copied off Roberuta. So you can also say Platinum are also knock offs. The difference between all these cups are the height and seals they use. For example Phantom (Platinum) cup kits are taller compared to other cup kits.
1SickGS300
15
10-01-13 06:04 PM
kim0217
13
11-13-12 09:59 PM
