stock hid question
Old Dec 19, 2007 | 09:34 AM
RI-Lex's Avatar
RI-Lex
I say 4300k is best thats what i use, but 6k is nice though
Old Dec 19, 2007 | 10:17 AM
chrispy's Avatar
chrispy
Originally Posted by DarKnight
Here you go http://www.xenonfactory.com/products...lb_philips.htm Just did a search for the bulb number on google.
Thanks, but I'm not paying $135 a bulb.
Old Dec 19, 2007 | 10:58 AM
kit cat's Avatar
kit cat
6k looks the best visually but if you're behind the wheel, it might be a little too blue.
Old Dec 19, 2007 | 05:51 PM
GSteg's Avatar
GSteg
Originally Posted by chrispy
Colorshifted bulbs are no longer the 85122+.
Chris, I think we throw out the term colormatched a bit too much
Currently there are 3 different Phillips bulbs (for OEM replacement)
-85122
Color Temp: 4100k
Lumens: 3200
-85122+
Color Temp: 4200k
Lumens: 3400
-85122CM
Color Temp: 4800k
Lumens: 3100
The 85122+ is recommended for OEM replacement because it's pre-burned in to give off a color similar to the 85122 after 100h or so. The 85122+ will give off just a bit yellow brand new, but I'm sure after a long while, it'll match the 85122 better. The difference with 85122CM is too obvious, even if you put one next to a color-shifted 85122.
But have you ever wondered why we all refer the OEM Bulb as 4300k instead of 4100k?
raptor22
Lighting
Sep 18, 2009 01:45 PM
garrick
Apr 11, 2009 08:41 AM
MLIAISON
Feb 22, 2008 11:20 AM
Anthracite SC
Lighting
Dec 3, 2003 06:19 PM
