Stop freaking posting this! I've seen this bumper all over Facebook when you posted it there. All I want to do is buy it, spoon it for 4 nights, and then take it to a bodyshop to make it fit the ISF
While I'm here, how cut up is the lower grill area for the FMIC and will the OEM grill fit back on there?
I won't clog up this thread with questions, as I am interested, but,
-is this plug and play for any 2IS? What else is required?
-is there a lower grille with this as well?
-what is required to get these fog lights installed and working?
Thanks! Looks amazing!
1) It's plug and play. Just remove the black headlight brackets and grab a set of quick releases for your car.
2) My body shop offered to install a grille for free when they did the work on it. Yours may as well. It'll need a universal mesh cut to size, as the bottom grille is much larger than OEM, hence the aggressive look.
However, it's not cut up at all. I did zero mods to it in order to fit the FMIC.
3) Cut holes, press in fog lights, and tap the included wiring hardness into the stock harness (2 t-taps per side). Then you will have OEM fog functionality.
