SRT Intake & Race ECU for GS400
Just thought I'd post here too.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7956915218
Any questions call 760-931-9100
Thanks,
Gene
Sorry Jonny. I didn't know. Here's the info.
Off my 1998 GS400. Has about 15k miles on it. Works perfect. Has some scuff marks on aluminum tube section. I don't have the installation manual, but SRT can fax one to you.. Here is the SRT info:
"The High Flow Intake system adjusts the air-fuel ratio to optimal settings in conjunction with a high flow Intake system. The stock intake system from Lexus has deficiencies in supplying air needed by the engine. Swift Racing is proud to present the first ever High Flow Air Intake for the Lexus GS400. This system helps the engine breath much better and gives the car quicker acceleration and much crisper throttle response throughout the entire RPM range. It uses 3.5" mandrel bent steel pipes and 5061 aluminum heat shield, enamel coated and uses a 5" conical AFE lifetime air filter. It also includes an ECU that recalibrates the air-fuel ratios for optimal performance and enhanced fuel economy.
Performance gains: +30HP and +40ft/lb torque. MSRP $545.00"
Thanks,
Gene
rhuettner
05-29-08 11:30 AM
auwrx
19
03-11-03 04:04 PM
