ECU Computer Reset Today at 5K Service
Old Apr 9, 2007 | 08:10 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
It's learning gear selection patterns. If you're light on the gas, it will default to finding the highest gear as quickly as possible. If you drive harder, it will hold in gear longer for better acceleration. You can do the same thing by hitting the ECT power switch for those times when you want it to be more aggressive.
The engine will self tune in a matter of minutes, so pulling the fuses really does nothing to change the engine tune for any length of time. It really only affects the transmission.
Old Apr 9, 2007 | 08:11 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by Pwyll
I'm glad to see this has been successful for some of you guys.
Question. I understand that if you disconnect the negative to the battery, the radion presets will be wiped. What about other presets such as seats, etc. BUT MORE IMPORTANTLY, THE NAVIGATION SETTINGS??
Anybody know?
Thanks
Yes. Your nav will be reset as well (at least mine was when I removed power to it.) I was mighty unhappy about that.
Old Apr 9, 2007 | 08:12 PM
caymandive's Avatar
caymandive
11 Second Club
Anybody know?
Thanks
I know for a fact if you remove the positive end from the battery, you won't lose radio presets. Seats are easy..just make sure the seats are where you want them so it's an easy set again. Navigation..i'll have to look into that one, but I have a feeling that since the radio presets were still there, that the Nav settings are also still there.
Lobux..you said you lost your Nav? Now I'm wondering if there is a difference to removing positive or negative from the battery to do a reset.
Old Apr 9, 2007 | 08:25 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
The fuse is on the positive side. I pulled the TV1 fuse to intentionally reset my nav. It killed everything. Same as if I'd pulled the battery cable. I'd test it but I don't want to lose all my nav data. I could test this just before I leave for Atlanta though since all the California data will be useless there. That won't be for another month though.
Stuff I lost by disconnecting power - seat position and key fob affinity, seat position, nav data, window position (had to re-initialise the windows.) None of this was from disconnecting the battery, it was from disconnecting various parts for other reasons. Oh, yeah, I did reset the ECM once because I disconnected it and pulled it out to see if I could identify the processors in it.
Old Apr 10, 2007 | 10:36 PM
cre8's Avatar
cre8
lobuxracer...
Old May 19, 2007 | 11:29 AM
ben_r_'s Avatar
ben_r_
Wow, Im going to have to try this now! Its been about 2K miles and Ill admit I was really babying it the first 1k... now I drive her like shes mine!
Old May 19, 2007 | 11:36 AM
Lexmex's Avatar
Lexmex
This is a trick we have been doing for a while in the RX300 forum and involves pulling a single EFI fuse or the negative battery cables. Resets CELs temporarily, unless something really is wrong. I find that that pulling both cables has a better effect and it needs to be more than a minutes as sometimes there is some juice left in the system/capacitors.
Old Jul 23, 2007 | 08:29 AM
Benjamin T's Avatar
Benjamin T
does this trick also delete the cel codes from the ecu memory, or is it still stored inside?
Old Jul 23, 2007 | 07:42 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Not necessarily. You really need an OBDII scanner to reset the DTCs reliably.
Old Jul 23, 2007 | 09:11 PM
andoy's Avatar
andoy
Will resetting the ECU be beneficial for 6MT owners?
Old Aug 26, 2007 | 09:24 AM
iSuxeL's Avatar
iSuxeL
Can anyone tell me if I need to disconnect the negative to install HIDs in my fogs?? Or Change out the OEM HID headlight bulbs??
Old Aug 26, 2007 | 10:09 AM
MoLexus's Avatar
MoLexus
No just turn off the car and you should be fine.
Old Aug 26, 2007 | 11:48 AM
A.C Milan's Avatar
A.C Milan
i disconnected my battery(negative first) and i'll be back home on wednesday,i'll let you know what exact settings has been erased.
Old Sep 2, 2007 | 06:55 PM
burnabykid's Avatar
burnabykid
Thanks for the information, again CL is a good source when your in a bind because of the members here. Had to reset my ECU when i got a check engine/VSC error after my fujita intake got installed. Anyhow, my question is i noticed that a few things were reset such as avg gas mileage and the seatbelt alarm, but how about the settings for the car that the dealer does for you on your first service? i.e. the lighting level for your automatic headlights which i had asked to be set at level 2, are they reset back to default now too?
Old Sep 3, 2007 | 08:55 AM
ecr527's Avatar
ecr527
I just tried this just now. That's for the head's up on it not starting the first time around. I'm sure that would have freaked me out if I didn't know!!
