GS uas rear bracket length?
Old 04-29-13, 08:10 PM
HrdPrkDGS4
HrdPrkDGS4's Avatar
Default GS uas rear bracket length?
I have bags over coils but all down I sit at the wheel in the rear id like to tuck maybe an inch. The rear brackets are custom, I think they may be too long anyone have a length ? Thanks in advance...
Example:
Old 04-29-13, 09:07 PM
SoCal_450h
SoCal_450h's Avatar
I believe that parts are same, the bracket on the top of the struts is the one that determine how low your car when aired out. (the red top on pic).
at least that what I know if you use Megan LP
Old 04-30-13, 03:54 AM
HrdPrkDGS4
HrdPrkDGS4's Avatar
Thanks for the response. Mine has that top tube bracket like twice the length with no extended top hat. Did you buy your bracket or make it? Length?
Old 04-30-13, 07:18 AM
SoCal_450h
SoCal_450h's Avatar
I bought from UAS, but they already pre-made the tube bracket, the extended top hat bracket on the other hand Zack (UAS) have to made custom. as far as for the length, I don't remember....sorry.
Maybe other member can chime in. BTW, what kind of struts you have? if you have megan, you know you have to cut it, right
Old 04-30-13, 02:39 PM
HrdPrkDGS4
HrdPrkDGS4's Avatar
Yeah they've been cut they're tein coils, maybe ill take it down an inch on the tube and weld it back up ill past a pick aired out. Thanks for your help
Old 05-11-13, 09:33 AM
HrdPrkDGS4
HrdPrkDGS4's Avatar
Ok one more question, seems like my top piece is good. Anyone have the length on the bottom? Mine may be too long to lay out... Very irritating. Thanks again in advance
Old 05-11-13, 05:41 PM
swtjlsy
swtjlsy's Avatar
should be around 1-1 1/2 inches of tube rewelded on to lay the car out. most shop make so you can still drive when airred out so they don't get sued. taht out your rear and post I can help with design if you need it.
Old 05-12-13, 02:26 PM
HrdPrkDGS4
HrdPrkDGS4's Avatar
Thanks yeah if you could, my bottom tube is almost 5" long!
Old 05-13-13, 06:48 AM
swtjlsy
swtjlsy's Avatar
is the how much thread you have left or is it from the eye up post some photos so we can see how it was done to better help you out
Old 05-13-13, 03:07 PM
HrdPrkDGS4
HrdPrkDGS4's Avatar
Ok ill get under there today but 5" is from the bottom of the tube to the bottom of the bag then add the "eye".
Old 05-14-13, 08:19 AM
swtjlsy
swtjlsy's Avatar
I will post up pics later on today
redb202
Suspension
13
01-31-15 12:14 PM
KennedyN
Suspension and Brakes
14
02-22-14 10:01 PM
HrdPrkDGS4
04-30-13 04:32 PM
I'mStock
38
04-08-12 06:32 PM
Quick Reply: GS uas rear bracket length?
