Volk AV3
Old 02-27-01, 10:56 AM
RacingAristo
Guest
Posts: n/a
The wheels are 18" in diameter by 9" wide. They are 5 lug pattern with bolt circle of 114.3mm (or 4.5"). These wheels have 10 holes but both sets of holes are the same bolt pattern. The have a postive offset of 44mm (+44 offset)(6.25 backspace). Could those fit on 2001 Lexus GS430 without any kind of spacer and modification? Thank you.
Old 02-27-01, 11:08 AM
JacobT
Guest
Posts: n/a
You should have no problem to fit those wheels to you GS430. It'll look nice on your car just like Mariusz's.
Old 02-27-01, 12:45 PM
RacingAristo
Guest
Posts: n/a
But I thought Lexus GS430 has offset +45 but Volk AV3 is +44. Does Mariusz have the same set of Volk?
Old 02-27-01, 12:55 PM
JacobT
Guest
Posts: n/a
+44 offset in the front for AV3 should also clear the big brake calipers. I have RH C5 which is streight spoke design with +44 offset. It almost clears the Supra TT caliper, with the curved spokes design on AV3, it should be no problem.
Old 02-27-01, 03:25 PM
RacingAristo
Guest
Posts: n/a
Thanks for the respond, Jacob.
What is the biggest width I could put in GS without having tires to hit the inner wall? And for 18x9, what size of tire should I be looking for?
Old 02-27-01, 03:41 PM
JacobT
Guest
Posts: n/a
You can have 245 front and 285 rear without any rubbing problem. If you have 18x9 all around, you can try 245/40/18 for all 4 corners.
Old 02-27-01, 07:29 PM
RacingAristo
Guest
Posts: n/a
Does anyone know where they sells new tires cheaper than tirerack.com?
Old 02-27-01, 10:46 PM
GlobeCLK
GlobeCLK's Avatar
try America Tire Co. They match prices, even tirerack ones. Even if it's not cheaper, it's better to buy tires at a store (they offer free mount on all tire purchases) than online.
Old 02-27-01, 11:21 PM
RacingAristo
Guest
Posts: n/a
Do they have a website or you have the address for American Tire Co.?
Do you live in Cerritos too?
DallasLex
02-10-08 07:26 PM
diamondmit
03-16-07 11:55 PM
Escobar
21
06-13-05 06:22 PM
SilverGS43
03-08-05 01:32 PM
Quick Reply: Volk AV3
