help a rookie out
Old 07-08-03, 08:47 AM
RIPP7399
RIPP7399's Avatar
Default help a rookie out
what offset do i need to have to run 245/40/19's or a "fat setup" on my 99 gs 300.
i have 235/35/19's now and they like less than a 1/2 inch rubbing the control arm bolt.
dont knwo what offset they are but i will find out and post.guy at my local tire store says there
is no way i can run 40's ???????????? any help you can give this rookie just getting started
would be appreciated......
i'll post the offset i have now as soon as i find out what it is
Old 07-08-03, 09:19 AM
JacobT
Guest
Posts: n/a
With +38 or lower offset, you can clear the upper control arm bolt.
Old 07-08-03, 09:31 AM
RIPP7399
RIPP7399's Avatar
So if offset is +41 will that work???? or does it need be +38, +37 or +36 to work...
wasnt clear which way "lower" meant.....
Old 07-08-03, 11:41 AM
JacobT
Guest
Posts: n/a
"Lower" means +38, +37, +36.... +41 is really pushing, it will be really really close to touch the upper control arm depends on the tires you use.
diljay
Suspension and Brakes
14
11-04-20 12:42 PM
Scythe
03-12-08 11:38 AM
Pdiddy
09-03-07 09:38 PM
05ES330
10-10-05 11:49 PM
BLu_Gs3
06-08-03 06:04 PM
Quick Reply: help a rookie out
