All Weather Tire Recommendation for IS250 AWD
Old 11-24-13, 06:16 AM
kb42
kb42's Avatar
Default All Weather Tire Recommendation for IS250 AWD
We have a 2007 IS250 AWD with 52K. We want to change from the potenza's that are currently on it to an all weather tire. My son has a 2009 M5 and an Audi A4 and says that we should look at Continental DWS tires. I can get them locally from Dunn tire or Mavis/Cole for about $600 "out the door" price but I read the comments and the tires are short lived, maybe 35K instead of the 50K the manufacturer says. This car gets no more than 8K/yr. Any recommendations? Also when outside temp goes down the low pressure indicator goes off. I have taken it to the local tire guy and they brush the corrosion off of the rim (original) so the bead reseats and it works for a few months. Is this common with aluminum rims?
Old 11-24-13, 10:06 AM
Raybean
Raybean's Avatar
i run Continental ExtremeContact DWS's in both of my cars. they are great tires. as for low tire pressure light turning on fill your tires a little more then what it needs. when it gets cold out tires loses a bit of air. so if it needs 32 psi fill it to about 37 psi and you should be ok. everytime i change tires at work i always brush off the beads reseat with a die grinder and put bead sealer. i seen many techs at work not do this and it so happens could leak air sometimes. Nothing worst then having customers come back saying you did something wrong and you end up having to fix your mistake for free.
Old 11-24-13, 10:20 AM
reyoasian
reyoasian's Avatar
conti dws +1000000
Old 11-24-13, 11:57 AM
nabbun
nabbun's Avatar
Pirelli Cinturato P7 All Season Plus.
Or you could buy my RE30s that have Goodyear F1 Asymmetrical 2. 18 x 9.5 +35. 255/35-18 lol
Old 11-24-13, 12:25 PM
ncsu-tc
ncsu-tc's Avatar
I just put a set of Michelin AS3's on 2 weeks ago. They are worlds quieter than the ****ty Bridgies that came on the car.
So far I am pleased with them.
Old 11-24-13, 12:42 PM
Samieee
Samieee's Avatar
Originally Posted by reyoasian
conti dws +1000000
x1000000....
Old 11-24-13, 03:12 PM
nabbun
nabbun's Avatar
Tough choice between Michelin A/S 3 and and Cinturato plus. Conti DWS has some catching up to do.
Old 12-01-13, 08:54 AM
echunks
echunks's Avatar
Hankook Noble 2 S1's ride really nicely and have excellent grip when cornering. They are usually priced cheaper than the other brands mentioned previously. Give them a look.
Old 12-04-13, 08:03 AM
zig@tr
Former Sponsor
zig@tr's Avatar
The Continental is a nice tire and it does great in snow/ice if you see any winter weather. Although the new Michelin Pilot Sport AS 3 mentioned as well will probably give you a quieter and smoother ride overall. The air loss issue you describe is just pretty typical anytime the temperatures drops significantly, I doubt you have any issues with your wheels in this case because if you did have a corrosion problem you would lose air at all times not just when it gets cold
Air Pressure, Temperature Fluctuations
mrraider
02-04-14 09:12 AM
sallydrive
10-15-11 02:28 AM
LIS350A
01-23-09 01:00 AM
mlee21
12-29-08 09:36 PM
BmoreGS4
10-30-07 08:50 AM
Quick Reply: All Weather Tire Recommendation for IS250 AWD
