12x1.25mm vs 12x1.50mm
Old 07-16-13, 06:47 AM
ldc
ldc's Avatar
Default 12x1.25mm vs 12x1.50mm
Hey guys, just wanted to know if i can use 12x1.25mm nuts on Is250, given that oem is 12x.1.5mm.
I bought a set of Nissan wheels and it comes with longer nuts and i'm sure they are 12x1.25mm.
Old 07-25-13, 11:11 AM
zig@tr
Former Sponsor
zig@tr's Avatar
No, those numbers are the thread pitch and are not interchangeable. If you were to try a lug nut with the wrong thread pitch on your studs it will cross thread and damage the studs.
Old 07-27-13, 05:54 PM
ldc
ldc's Avatar
I knew that might be the4 case. I got two other sets to fall on. One is my originals and the other is a set when i bought my last aftermartket wheels and which the shop put them on for me, I assume these are the correct nuts.
Old 07-28-13, 10:28 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
they should spin on easily by hand all the way down, if so, you should be good (though sometimes a slightly larger lug nut will do this and still not be correct)
Aspect
07-11-17 03:21 PM
2ndgen400
05-24-16 01:27 PM
step2me
05-10-12 02:19 AM
nar8ta
09-07-10 07:35 PM
dung0981
CL of Southern California
04-14-09 04:43 PM
Quick Reply: 12x1.25mm vs 12x1.50mm
