My new rims - RAYS - Sebring
Finally I got the valve stems for the rims, so I went to install the tires, rims and alignment done about last two weeks.
The rims is by RAYS, 19x8.5 and 19x10, using 245-35-19 and 275-30-19 S03, the both gap I set to slightly less than 2 fingers. The rims design is going deep toward inside the rim center, about 1" deep in front and 2" deep in rear, I like it very much!
The driving feeling is much different than before, feel heavier when start and understeering when making a turn, but the handling is better than my original 17".
Rims w/o lips always look bigger. Very nice I dig it..Im also buying a rim from Rays, i should be getting it soon.
How does the tires n rim combo feel when ur driving in the street?
By the way, springs or coil.? If springs, what kind?
aldo23, which rims you getting from RAYS?? About the road feeling, I feel the road much more than the 17", the S-03 done very good job, very quiet and grip! I have a TEIN-HA installed, 10/8 setup. Last thing to mention....you may have to set your shock stiffer, otherwise rub the fender may resulted, because it happened on me before!
KevGS4
KevGS4
Im putting on these babies..
http://www.3rotor.com/images/tas02/tas10.jpg
I'm going w/ a fatter tire, or some call it the "fat set-up". I want more comfort, well, thats what I hope. As for drop, I plan to get H&R springs. As for rubbing, and rolling fenders, I already have an idea that I may have problems(thanks to Cerebrus's help) due to my offset, and width of the front rim. For the front I got a 19x9 38offset, and Im being told I should get a 8.5.I guess we'll see...
KevGS4
KevGS4
Glad to see you finally got those rims on the car! If you are rubbing, you may consider rolling the fender but I think going ahead and cutting the fender works out better. Couple of shops warned me away from rolling due to the possibility of creating a visible ripple in the fender or damaging the paint. RMMGS4 has the rear fenders cut -- he did not even notice until I pointed it out.
aldo23 - it is a nice rims through, I like a deep dish too!! Post some pics when you got it!!
redgs4 - thanks for the info. That's why I rise it a bit like about 2 fingers gap between that, so far the ride is comfortable and not so stiff. Unless there has a big hole, it never rub the fender again. Hey....do you still remember how much the original price for that rims?
KevGS4
KevGS4
I don't remember the price, sorry.
You may not rub now, but load up a few other people and the car will settle and you will rub. Better just to go ahead and take car of it now, IMO.
