Excessive Tire wear problem
I have a 2008 Lexus LS460L with Vossen VVS-075's on it.....the front tires are Michellin XSE 245/40R 20's.....I am expriencing some serious road wear on the inside tread of both tires so much that they are making some bad road noise....The tires only have about 8k miles on them.....I have had the front end aligned as well.....Has anyone had the same problems with these tires or wheels?? I cant seem to find anyone including Lexus that can help me solve this problem!!!
Thanks
Thanks
Maintenance Moderator
Thanks
Thanks
that being said, I'd love to see the alignment numbers... When it is excessive wear like that, it is usually a combination of high negative camber (some is spec'd by Lexus) and excessive toe out or in...
