question about tires size...
Old 07-07-07, 04:27 PM
HYPERBOY
HYPERBOY's Avatar
Default question about tires size...
if i were to put a 06 ls430 rim on my 01 es300 (btw same offset and everything) what profile or tire size should i get??????
Old 07-07-07, 06:17 PM
bb430
bb430's Avatar
For 18" 245/40/18, 17" 245/45/17...
Old 07-07-07, 06:36 PM
HYPERBOY
HYPERBOY's Avatar
im getting the 18" but is that a low profile.... cuz i dont want the rim to rub
Old 07-07-07, 07:52 PM
bb430
bb430's Avatar
This is the right diameter for ES300 with 18". I think the OEM width is 7" and LS wheel has 7.5" therefore 245. 40 would make you the same diameter as the OEM 16" 60 series tires. You could do 45 to give you more profile but you will be driving faster than your speedo says...
By the way if you used 17" then it should be 245/50/17, not 45 as I had made a mistake... You can check the tire fitment using Tirerack's website...
Old 07-08-07, 07:42 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
something is wrong...
245/40-18 and 245/45-17 are the same diameter both about 25.7"
stock size is 205/60-16: diameter of 25.68"
you were correct the first time...
Old 07-09-07, 08:32 AM
SoCalSC4
SoCalSC4's Avatar
My experience with the ES has shown that a 245 may have clearance issues on the rear strut housing. Not sure how it'll work in combination with the stock wheels and offsets, but a 245 is pretty wide on a 7.5" wide wheel, making it difficult to predict how far the tires will "bulge" past the rim flange. This balloon look seems okay on a large car like the LS, but it may look a little odd on the ES.
225/45-18 is a safer fit, and (I think) will look better on the narrowish wheels.
Old 07-10-07, 09:35 PM
HYPERBOY
HYPERBOY's Avatar
thanxxx but new question..... ls rims r out i found 06 gs430 rims there 18" also i have wats the tire size for this??? will it be too wide??? i alsooo am gonna get a very low profile tire, is 225 the lowest?? or wat????
ZaliaMesa
03-30-18 04:54 PM
Farino81
SC- 1st Gen (1992-2000)
09-15-11 02:33 PM
hollywoods
08-20-09 07:57 PM
GoldGS3
10-22-06 08:15 AM
Neil64
07-11-06 09:14 AM
Quick Reply: question about tires size...
