What size tires?
What size tires?
I currently have Yokohama AVS Sport 265/30/19 on my dropped gen1 GS300 with 19x8.5 rims, I need new tires what size is best for my car, I was told that the tires I have are on the very large end for my size rims. What should I get?
275/30/19
255/35/19
245/35/19
I am afraid to get the 35 series as I already slightly rub when I turn very sharp from a stop. But I want what's best for my car and my size rims.
Thanks!
275/30/19
255/35/19
245/35/19
Thanks!
Originally Posted by BR1AN
265/30/19 is a bit much it for a 8.5 width wheel. The highest you should go with is 255/35/19, but 245-35-19 would be perfect.
Now obviously the 245/35/19 is narrower than what I have now which will reduce rubbing in the width, but it is also a 35 series instead of the 30 I have now; how much do I need to worry about it rubbing more or worse than it does now since the tire is taller? I can also get a 235/35/19 but now I keep going more and more narrow of tire. I want as much rubber as possible, but want to do is safetly. The tires I had worn unevenly on the inside edge, did that have to do with the fact that those larger tires were squeezed onto a smaller rim?
O.C. Lucky Strike Fanatic
The correct tires for a 19" rim is 245/35/19. Another way to prevent any rubbing of the fender on sharp turns is to get a set of coilovers since they will stop the travel of the spring.
Also note that certain tires will be beefy such as michelin pilot sports in which they are boxy.
VIP|EXEstyle セルシオ
And as LexAristo mentioned, certain brands of tires have differently shaped sidewalls. For example, Michelin Pilot Sports have a square-ish/straight sidewall, whereas Falken tires have a more round/curved sidewall.
