What Brake Pads & Hi Temp Brake Fluid are you using.
I have a cross- drilled and slotted rotors and been trying to find the best combo for stock calipers. This is is for a SC400. I have been using EBC's in the Front and stock in the rear, and DOT 3 Fluid. Thanks
Philly
Philly
ya know i was thinking about the samething a few days ago but then i thought if we get the twin turbo's were gonna have to upgrade the brakes anyway...im rollin on chrome TT wheels now so i might just keep those and get the supra TT brakes...
CEO
CEO
When I had the stock brakes, I had premium pads from Napa called "Application Applied". They were low dust and had pretty good bite. I was using unknown fluid (Was green when bled..LoL). Thats why I upgraded to TT brakes...Much better.
For my TT brakes...., I'm using the OEM Pads (TOOOO much dust!!) and Motul DOT 4 fluid.
Forum Administrator
Good fluid choices are ATE Super Blue (what I use), Motul 600 and Valvoline Synthetic (cheaper, but boiling point isn't quite as high).
Here's a thread I did w/ some research I did looking into brands
https://www.clublexus.com/forums/sho...hreadid=121608
Originally posted by RA40
Where can you find the Motul and ATE?
I have Valvoline syn in there now yet I'm due for a brake bleed soon.
Forum Administrator
Note that the ATE comes in two colors ATE Super Blue and ATE Gold. Same fluid, you're just supposed to switch between the two so you can tell when you've bled all of the old fluid out. Pretty cool
I think I am going to try ATE. I heard the ATE SUper Blue stains your fluid resovoir completely, Is thier ant truth to that? Also has anyone used anything except stock pads in the rear? SliderSC I was think about using the Axxis because they are cheaper than the EBC's. How is the brake dust on your wheels?
Philly
Philly
tommyt811
Suspension and Brakes
02-01-08 05:47 PM
