What kind of problems are associated with 20" wheels?
Hey guys, I am looking at buying some 20" wheels for my 2000 GS300. The exact size is 255/35ZR20 up front and 285/30ZR20 in the rear, they all are 8.5" wide. What kind of issues am I going to run into by putting these large wheels on my car.....how much different is my car going to handle, ride, brake from the stock version and difference in road noise???. Do I have to upgrade the brakes for this type of mod? I really do not want any change in my stock suspension feel, because it rides so nice now....but will it look goofy without it lowered a bit?
Let me know your thoughts people!!!!
Thanks! Spence
Thanks! Spence
Former Sponsor
First off, if your gonna run a 8.5" rim all the way around, you wont be needing those 285s out back.
Secondly, if you run a 255-35-20 up front, you must have a CAREFULLY chosen wheel offset in order to drop without rubbing, and trust me, with 20" wheels, you WANT a drop!!LOL
There are lots of posts about 20s around, for the most part:
Slower acceleration
Major bumps more pronounced,
Cost of repair/replacement etc etc
Slower acceleration
exclusive matchup
with 20s you have to be very careful coz' it's out of spec. 255/35/20 is very marginal and offset if very important, otherwise you will hit the suspension bolt on the suspension, very bad idea. and yes you shouldn't put 285 in the back on just 8.5... that's for staggered setup. with 20s rubbing is usually the major problem, specially if you lower it. you can easily hit the top (synergy, jawnthen), or hit the outer fender tab. and when hard lock turn, you will most likely rub the front and back of the fender
Master Thread Closer!!
Hey Okie -
For 20x8.5 all around...I'd say 245/30/20 tires all around is best. Make sure the wheel clears the brake calipers....thus, the offset is critical....otherwise fender/caliper rubbing will occur (assuming you have already dropped the car). If the wheel comes in High Disk....even better.
O.C. Lucky Strike Fanatic
Originally posted by DGOT20s
Slower acceleration
Slower acceleration
But with TC and LSD installed, you'll make it up for the acceleration loss And with big brake upgrade, you also add on to your stopping power That's why I do not see any disadvantage of installing 20's but only increasing the GS street appearance I went to Costco the other day and the guy at the door stopped me from rest of the customers just trying to find out what rims and sizes I have on my car
Former Sponsor
For brakes, I got the Rotora pads already installed, I'll probably just add Bradi X-drilled rotors to help out!!
So umm . . whats the final size on 20's? cause im about to get me a set real soon . . and i wanna drop my car about 1.5 -2in. and whats a good offset to have the car dropped??
exclusive matchup
