Suspension Springs, shocks, coilovers, sways, braces, etc.
Rubbing
Old 04-02-15, 08:42 AM
hube
hube's Avatar
Default Rubbing
Hi all,
I have a question relating the rubbing of my GS. After the RSR lowering spring and fitting the VFS-2's my car rubs. It hits the plastic, what are they called, extensions at the side of the wheel housing of the front wheels. When you put your hand between the fender and the tire and feel the inside of the plastic wheelhousing, you'll feel at a certain stage a protruding bit of plastic. The tire hits that.
What is the best way to deal with that? Bending with a bit of heat, will that work? Or did you guys sort this out differently?
Can you please tell me how you solved this. Thanks in advance!
Old 04-03-15, 01:56 PM
hube
hube's Avatar
Update,
Bending the plastic with a heatgun dit most of the trick. There is still a little rubbing in the rear. Next week there will be a set of bump stoppers installed on the rear shocks. That should sort the last bit out.
Old 04-05-15, 09:32 AM
mmilo1
mmilo1's Avatar
Car looks great man! I'm running into the same rear rubbing issue after installing the rsr down's and 20" vossen wheels. It only happens when I drive over larger dips in the road though.. Please let me know if you come up with a solution
Old 04-05-15, 01:37 PM
hube
hube's Avatar
Yes, large dips in the road. That is also my issue. I am serously scared of hitting a ditch like that doing 260kph on the Autobahn.
Anyway, these bumpstops were adviced: http://eibach.com/america/en/motorsp...ries/bumpstops
Anyone having experience with this?
Old 04-08-15, 12:29 PM
JoshIS408
- - G T V I P - -
Forum Moderator
JoshIS408's Avatar
What you are most likely rubbing on isnt the plastic linear itself, but more so the bracket which holds the front bumper on. This was a common issue with the 2IS Chassis, which was remedied with the following modifcation:
There are multiple way of doing the tab modification, here is another members approach at the issue:
Originally Posted by kumquatism
These aren't the greatest of pictures, but it's pretty difficult to take pictures without removing the wheels. There are certainly other ways of doing the tab modification, but this is what my car has.
It should give you a general idea of what needs to be done.
Hope this helps!
Old 04-09-15, 07:27 AM
hube
hube's Avatar
Thanks for the information! I'll let them look at that!
Old 04-25-15, 01:55 PM
Polo708
Polo708's Avatar
mine rubs badly in the rear, not in the front (I dont think). I have the Tanabe NF210s and the springs finally settled on me. Rubs real bad in normal mode and kinda bad in S+
Old 04-25-15, 01:57 PM
Polo708
Polo708's Avatar
Originally Posted by hube
Update,
Let me know how those bumpstops work out for you... I have to do something with my rear. Its driving me crazy. A luxury car sounding like a POS honda civic right now
Old 04-25-15, 08:00 PM
hube
hube's Avatar
Will do. There was some delay, the appointment to have them fitted is the 19th of may.
Old 04-27-15, 11:51 AM
2_xplicite
2_xplicite's Avatar
What size tires are you running? I just dropped mine on Tanabe NF210s also and about to pull the trigger on some wheels. I'm afraid I might run into the same issue with rubbing.
Old 04-27-15, 03:06 PM
terrycs
terrycs's Avatar
It's not the springs. Many of us are using them without issue. There seems to be occasional problems with the standard Vossen wheel offsets.
Old 04-28-15, 12:16 AM
hube
hube's Avatar
Let me post the whole speclist:
Front:
Wheel 20' 9j +32
Tire: 245/35/20
Rear:
Wheel 20' 10.5j +45
Tire: 275/30/20
Wheels: Vossen VFS2
Tires: Bridgestone Potenza s001
Loweringspring: RSR Down sus https://www.rs-r.com/product/lexus-g...-springs-2013/
Old 04-28-15, 06:57 AM
alex909
alex909's Avatar
I just got my Vossen VFS2
F 20" +32
R 20" +45
and RSR super down springs
couple members have told me to go with
245/30/20 F
275/30/20 R
with no rubbing issue
Old 04-30-15, 02:51 PM
Polo708
Polo708's Avatar
I'm running the 275's
I didn't rub at all for the first 4-5 months the springs were on. Once they "settled" they are too soft for me and rub the fender on any decent bumps. If I have my small kids in the back then it's over... It rubs every bump
Old 05-19-15, 04:18 AM
hube
hube's Avatar
An update. Today the car is in for the bumstop solution and I received this image back:
Not something I like to see. Right rear shock is busted....
So far the RSR downsus lowered my GS450h f-sport 6.5cm instead of the 3-4cm claimed on their website. This was the main reason for my rubbing issues. Which of course helped a lot towards the shock failure.
Quick Reply: Rubbing
