Suspension Springs, shocks, coilovers, sways, braces, etc.
Ride Quality after lowering
Old 04-30-14, 07:34 AM
IXI187IXI
IXI187IXI's Avatar
Originally Posted by jmack2688
However philly roads are the worst...
preaching to the choir on that one
yea it definitely doesnt sound right. yes a lowering spring will wear out a shock quicker but i highly doubt this is your case. did it ride perfectly fine before the lowering springs? did you notice this right after the car was lowered?
Old 04-30-14, 04:34 PM
jmack2688
jmack2688's Avatar
[QUOTE=IXI187IXI;8513106]preaching to the choir on that one
yea it definitely doesnt sound right. yes a lowering spring will wear out a shock quicker but i highly doubt this is your case. did it ride perfectly fine before the lowering springs? did you notice this right after the car was lowered?[/QUOTE The ride was perfect before the lowering springs, I didn't notice until soon after they were installed, as the weather cleared up I drove a little more aggressive until...
Old 05-01-14, 04:42 AM
IXI187IXI
IXI187IXI's Avatar
yea if it was fine before and now all of a sudden it sucks, i would say something was wrong with the install. it would be a very high coincidence that the shocks blew already. i know of a good shop, a little out of the way for philly but thats where i took my car to have the bcr's dialed in and alignment done. they were actually the ones that give the info for the spacers for the wobble/vibrations as well.
Old 05-01-14, 12:07 PM
jmack2688
jmack2688's Avatar
as long as it's done correctly I don't care, I still need an alignment anyway
Old 05-02-14, 02:38 AM
IXI187IXI
IXI187IXI's Avatar
their a little expensive when it comes to alignment but i highly recommend them. they took everything into consideration even my wheel width's and offsets to dial it in. very good shop and popular on my other local forum.
R/T Tuning
Old 05-02-14, 08:34 AM
jmack2688
jmack2688's Avatar
R/T Tuning
Thanks allot, the shop that mounted my wheels suggests coilovers all together, he said never mount lowering springs with stock shocks, but I'll see what they as well
Old 05-02-14, 09:40 AM
IXI187IXI
IXI187IXI's Avatar
yea lowering springs on stock shocks just wears them out quicker as the shock doesnt have the same amount of travel as it does with oem springs
Old 05-07-14, 07:53 AM
jmack2688
jmack2688's Avatar
I scheduled an appointment, they're booked until the first week of June. The car shutters when I hit the brakes as if I need motor mounts ever since the wheels were mounted, I'll ask them about that too. Thanks again.
Old 05-07-14, 09:46 AM
IXI187IXI
IXI187IXI's Avatar
aftermarket wheels? id check to see if the lugs are tight.
Old 05-08-14, 06:42 AM
jmack2688
jmack2688's Avatar
Yeah, smh that's dangerous
Old 07-28-14, 06:55 AM
ReyRey305
ReyRey305's Avatar
I had the f-sport springs on my RWD for a few years. I just got the BC-R coil overs with Swift springs upgrade, SPC Front ball joints and Rear Control Arms. All I have to say is i am extremely happy with my ride. The bottoming out feeling is gone and I can control the softness or hardness of my ride. I would high recommend this coil over setup. If not, then I would look into some custom Swift Springs to replace the F-Sport springs.
Old 08-06-14, 10:00 PM
noeazzzy
noeazzzy's Avatar
Do you have pics of your car with the BC swift set up? Btw what are your spring rates?
Old 08-16-14, 09:13 PM
darinmg
darinmg's Avatar
OP...Did you get any resolution on this? Was it the bump stops?
darinmg
08-21-14 06:47 AM
CallmeQ
GS - 1st Gen (1993-1997)
06-21-11 04:13 PM
06CWIS350
Suspension and Brakes
08-07-07 11:04 AM
sincityIS
17
07-25-07 08:35 PM
howiedoit
01-20-03 02:47 AM
Quick Reply: Ride Quality after lowering
