TRD brake system?
Old 10-19-03, 09:20 PM
soj17
soj17's Avatar
Default TRD brake system?
Well I'm new and I have alot of questions so here goes one of many. I searched the other posts but can't find any info on the TRD brake kit for the GS400. Has anyone ever tried it or using it currently? I really would like the Brembo kit but don't want to spend $3000 on brakes when the TRD kit comes with everything front and rear, including stainless steel lines for $1400.
Secondly, I seem to be getting alot of road noise from the floor of the car at speeds of 80 mph or greater. I still have the stock 17 inch tires on the car (Goodyear RSA) and I was wondering if there is anything I can do to reduce the noise such as dynamat the floor etc. I plan on running some 19" wheels when I get the funds together and I realize that this will increase the noise but I want to keep it as low as possible.
Seth
Old 10-19-03, 09:56 PM
GS4Will
GS4Will's Avatar
mind sharing with us where you found the TRD kit for $1400 front and rear?
there are actually two TRD set ups: one is from Supra TT set up, and another is from the LS430 set up
either one is great
thanks
Old 10-19-03, 10:32 PM
soj17
soj17's Avatar
GS4Will
I'm making an assumption here since based off whats listed in the pic.
http://www.l-tunedparts.com/html/partsordering-trd.html
Let me know what you think.
Seth
Old 10-19-03, 10:33 PM
jtanoyo1
jtanoyo1's Avatar
I think he's talking about the Supra TT setup. But then again, for $1400 that would have been too expensive. A TRD setup would have set you back over $2000. Where'd u get the hookup bud?
Old 10-20-03, 01:03 AM
HKGS300
HKGS300's Avatar
TRD sells several big brake sets.
TRD Japan has basically 2 sets for the GS, the low-cost range, which are the ones you are now referring at, and the Monoblock set.
In addition, TRD USA is also repackaging the Stoptech.
Old 10-20-03, 02:42 AM
Neo
The One
Neo's Avatar
Really? Do you have more info? Which StopTech kit? Cost? Pics?
Old 10-20-03, 08:53 AM
HKGS300
HKGS300's Avatar
I just checked. TRDUSA is probably only offering the (StopTech) bigbrake for the IS300. Could not find any info on a GS Bigbrake kit from TRDUSA.
Old 10-20-03, 06:42 PM
GS4Will
GS4Will's Avatar
i was told by two lexus master tech guys that the IS and GS share the same brake system. that is why the IS has excellent brake rating,even at stock set up
Old 10-20-03, 08:23 PM
HKGS300
HKGS300's Avatar
I think the design of the IS and GS brake pads are the same, and both use the same calipers, pads and rotors.
I expect that the brackets might be a little bit different tho. Probably because of marketing reasons TRDUSA did not introduce (or forgot to post on the website) the TRD"Stoptech".
Probably most people with GS will go for the Supra TT, while these Supra calipers need to be modified a bit before they fit an IS.
Old 10-20-03, 08:27 PM
Neo
The One
Neo's Avatar
Unless the GS people upgrade their wheels, the Supra TT calipers won't work for them either.
jsp0816
LX - 3rd Gen (2008-2021)
05-19-15 10:14 PM
FL1PP3D
Suspension and Brakes
08-24-07 04:22 AM
Altezza*9
16
04-18-07 09:54 PM
DrewGS4
11-05-03 05:48 AM
Quick Reply: TRD brake system?
