Front Brake Shim Kit IS350
I have the new low dust front brake pads in hand and also ordered the shims. My question is the shim kit comes with 2 sets of shims. One set mirrors the stock all metal ones. The other set is mostly metal, but has a rubberish black padding that comes in contact with the back of the brake pad. What is the difference and which should I use? I assume if I use the all metal ones I use grease, but if I use the black rubber ones that is there so you do not need to use grease maybe... Any help is greatly appreciated.
Thanks!
Thanks!
Use both types of shim! The rubberized coated ones touch the pads, the non-rubberized coated ones touch the calipers.
Pad -> Coated shim -> Non-coated shim -> Caliper
No grease is used.
Pads with wear indicators go on the inside.
Jeff
No grease is used.
Jeff
Perfect Jeff. Thanks! Exactly what I needed. I was going to start it last night, and when I saw 8 shims I didn't remember anyone in this thread discussing the "extra" shims. This was very helpful. I will replace them exactly as you are suggesting. Thanks for your time!
danais350
danais350
Any reason to not use any grease? I added some CRC brake quiet on the outside of the chrome shim that touches the caliper and piston and I added grease on the slide pins and contact points. My brakes were squeaking and so far it solved the issue for now.
If you've got noise issues and grease helps fix them, that's probably not a terrible thing. Lexus' fix for the noise was an updated set of shims and pads (the same ones the OP has) and the TSB specifically mentioned not to use grease (same as the original shims). I don't think there's anything wrong specifically with using grease, but they weren't originally designed to be used with grease (though the rears were).
Jeff
Jeff
would I need a new shim kit if I get the Akebono pads for the front? or just use the shiums from the original pads and ditch the shims that comes with the Akebono? this is for 2014 is350 fsport
Lexo_Tony
Suspension and Brakes
14
10-22-11 11:23 AM
