Quick question regarding lowering springs
Old 09-01-15, 07:04 PM
Tro209
Tro209's Avatar
Default Quick question regarding lowering springs
Hello once again everyone,
Im thinking of buying the H & R springs for my is350 soon and was wondering what exactly needs to be purchased when I do this. I will be taking my car to a shop to have it done, but seeing as how I'm not familiar with how lowering works, I was wondering.. Do I need to buy shocks or struts as well when I put the H&R's on? Or can I just put the springs on and be okay?
I am unfamiliar with how spring's and the like work exactly so if someone could please clarify, that would be great!
TL;DR Can I just install h&r springs? or do I need to do something else as well like shocks , struts etc..
Old 09-01-15, 08:29 PM
LexSense
LexSense's Avatar
Yes, you can just install the springs onto your existing shocks. The shop should have all the tools needed for the install.
However, if your car has some significant mileage on the shocks/struts then you might want to consider getting a new set to be installed along with your springs. (Since you are going to be having the assembly out for the spring install anyways)
Depending on how much lower the H&R will put you at, they will cause your shocks/struts to wear out a bit faster than normal.
In short though, you can definitely just install springs onto the existing shocks if you don't care about potential wear and or possibly having to do the job again at some point in the future.
For the most part you should be fine though and I'd say go for it!
Old 09-01-15, 09:28 PM
Tro209
Tro209's Avatar
Awesome! Yeah I'm sure my shocks have quite a bit of miles on them so I'll probably just do them as well , I suppose. Thanks for your help!!
Old 09-02-15, 04:23 PM
LexSense
LexSense's Avatar
Consider the Koni Yellow shocks if they're in your price range.
They are meant to handle the lowered springs setup and come with adjustable rebound settings
It would be the ultimate spring setup.
Old 09-03-15, 10:56 PM
Tro209
Tro209's Avatar
Definitely thanks !
bdoggie28
Suspension and Brakes
08-11-11 07:30 AM
SPKV6
02-06-11 03:10 PM
young's 96
06-13-09 06:31 PM
BigVIPness
GS - 1st Gen (1993-1997)
08-16-05 08:56 AM
xirforever
04-14-05 08:27 AM
Quick Reply: Quick question regarding lowering springs
