Camber Wear
Camber Wear
just got my IS250 last week and am planning to get RSR Downs and was wondering if these cars have camber wear issues or do they have camber adjustments? Thanks in advance!
Don't worry too much about camber. Just get an alignment after waiting for the a week or two for the springs to settle in and fix the toe adjustment. Toe is what really eats tires. Camber will eat tires but nowhere near the rate of what a out of toe specs would
-2 degree or more is a lot for street driven car, you will see significant tire wear. Not to mention you it contribute to more understeering. I personally would invest in a camber kit.
I've lowered a couple vehicles in the past Acura and Infiniti. and I agree around -2.0 camber is getting to be too much for daily. Tires will wear out maybe 20% - 30% faster and the stance starts to look a little too ricer for me.
Camber wear...
I have lowered dozens of cars and trucks of all types over the years, and have never experienced tire wear (other than rears due to HP issues!). Doing it right the first time, including a proper alignment, works wonders. See my posts in the thread link below. Pay particular attention to post #23 that may be beneficial to you.
https://www.clublexus.com/forums/sus...f-sport-2.html
What if it's just a weekend car? I drive 100miles total to work everyday and can't drive this car daily. Would you still recommend camber kit? I probably drive 150 miles top per week on my IS.
Why isn't anybody listening to me. Fix your toe and don't worry about the camber too much. Toe will eat the tires the fastest and will look like camber wear. I never have had a camber kit for any of the cars once every lowered and I lower my cars really low. You guys really want to straighten your camber back to zero and risk the chance of tire hitting our odd shaped rear fender arches?
What is the stock camber specs anyways? I've never installed camber kits as well and always opt for zero toe. I usually like -1.5-1.75 of camber. I will probably live with -2 for now after I drop it since I don't drive it daily.
It really comes down to this.... If SOME premature tire wear is acceptable to you, by all means bring the toe in after you lower it and call it a day. If you want it right, correct the camber. If 2* or more negative camber were not an issue for tire longevity, the factory specs for virtually any car manufacturer would be much wider. I personally am far too picky to not do it right the first time.
Toe, depending on severity, will often kill a tire much quicker than camber, although severe camber will effectively reduce the life span of a tire insurmountably.
It isn't rocket science, just basic chassis and suspension geometry that really hasn't changed much since cars with four wheel independent suspension (or even independent front suspension for that matter) were introduced to the market.
Even dinosaur vehicles with straight axles and king pins would have camber wear when the king pin bushings were worn, inducing camber wear when the tie rods were cherry and toe was set correctly.
Again, this stuff is as basic as it gets.
