Toyota Supra TT brakes
Hello, Forum
Are TT Supra brakes a direct swap to an SC300? if not what all is needed to do the swap like do I need Supra rotors or what else EXACTLY is needed? Thanks for all the input. I'm kind of on a dead line with this so the sooner I find out the better. Thanks again.
Best,
Ashtray
edit: I'm assuming for sure I'd need rotors but anything else specific?
Best,
Ashtray
Side note #1: I got my new LS400 rotors last week and they were 1.5 lbs and 3 lbs, respectively, lighter than listed. There's apparently quite a bit of variability in the manufacturing and batch specifications. I'm curious if the same applies to other lines. For example, the TT is more performance oriented and maybe there's less variability "allowed" in its rotors, so the extra 2 lbs of the LS rotors could disappear comparatively.
Side note #2: My LS400 pads (Wagner) arrived today and whoa are they heavy. 4 lbs 1 oz for the set, nearly half as much as one of the aluminum calipers!
As long as your existing brake lines aren't deteriorating, they should be just fine. For everyone that says braided SS lines give a noticeably better pedal feel, you'll find someone else who says they make no difference on modern cars and that any improvement you're feeling is simply from bleeding the brakes at the same time. Any time the opinions are split that evenly down the middle, I assume the improvements are purely in the aesthetics realm.
The only time you'll really notice a difference from rubber lines to SS lines is on a track when your braking hard for 20-30 min around corners your flexing the rubber lines as with the SS lines they won't expand and it'll have a more consistant brake feel
As for the LS rotors do they make "upgraded" rotors as in drilled or slotted? As the holes or slots won't do anything for braking performance there might be a weight loss minimal maybe but any weight loss is a good thing
Do the lines.
You're replacing everything else and you're going to need to bleed the system anyway. You might as well flush with new fluid and install new lines. Thats what I did. And if your lines were like mine, you'll see cracks form in the rubber as soon as you unbolt the calipers.
You will need to trim the factory dust shields unless you plan on getting the TT shields as well.
Don't know if there's a sponsor on here for as brake lines but I found a guy who makes custom lines for our cars in 4-5 different colors for $65 shipped you can look him up on facebook Raymond Chan
Sorry if I shouldn't be advertising for him it's just a really good deal I figured I'd share I have no affiliation with him or his business
I've seen his posts and considered them, but it scares me to try home brew brake lines. Has anyone put them to use and verified that the hose material and crimped connections are any good? I'm sort of surprised anyone would put their neck on the line selling such an important safety equipment item. Talk about legal risks!
Get TT calipers with DBA(disc brakes australia) TT rotors and stainless lines with rubber coating. dust gets inside between the metal pieces on braided lines and can corrode the rubber underneath, rubber coating keeps that from happening. you can find TT calipers at most parts store for only 100 bucks a piece (+18 core or something).
I currently have the LS brakes on my car, and if I were to do it again I would go with supra tt for better rotor and pad selection. I've been having a hard time finding performance pads for the LS brakes (the only ones that come to mind right now are EBC).
It really comes down to what you're trying to achieve with your car and how aggressive of a driver you are.
