08 GS suspension
Old 11-29-14, 07:49 AM
hanuman
hanuman's Avatar
Hi guys I have done a search for my specific problem. My gs460 has 50k miles and lately I hear suspension rattle that's what I am guessing now not sure. I thought it was my summer tire set up but the factory set up is worse with 18s. It's colder so that is part of the problem I am guessing.
Could the car have suspension issues with very low miles I plan to check the sway bar and links. What else should I check, are strut plates easy to see if there are problems.
The car sounds like an old car going over bumps and pot holes.
Thanks in advance.
Old 11-29-14, 08:02 AM
doctordank
doctordank's Avatar
May be a leaking or blown strut. My car only had 56k miles when rear strut went bad and like you, most noticeable over bumps. It was a good excuse to get coilovers
Old 11-29-14, 04:03 PM
LoveThatV8
LoveThatV8's Avatar
I'd check struts brotha since you've mentioned about noises over bumps and potholes as mentioned by doctordank. Happened to me as well in my G35 cpe, in my 06 GS430 I have drop springs (101k miles) but haven't heard any squeaks/rattles over bumps... Just hearing the mid-pipe scrape itself over bumps if I dont go sideways. Time for you to purchase airbagged suspension. Lol. Jk, get it on the lift and inspect it my man, can't really diagnose while you drive it. Goodluck.
Old 12-01-14, 11:20 PM
angus
angus's Avatar
Also the caster arm bushings are an issue in the 3GS - I replaced mine and it drives 2X better.
jfmjr
01-20-13 07:49 PM
S30ZG
12-17-11 11:07 PM
fosterjd24
Maintenance
04-22-09 10:49 AM
RA40
18
04-30-08 07:17 PM
luvmylexus
12-23-04 10:05 AM
Quick Reply: 08 GS suspension
