View Poll Results: OEM ENGINE MOUNTS vs. AFTERMARKET What do you prefer?
OEM
54.55%
AFTERMARKET
27.27%
Don't Care
18.18%
Voters: 11. You may not vote on this poll
GS3/4 ENGINE MOUNTS OEM vs. AFTERMARKET
Old 09-26-14, 10:37 AM
Tank
Tank's Avatar
Default GS3/4 ENGINE MOUNTS OEM vs. AFTERMARKET
Hello All,
Curious about engine mounts.
In all your experience, do you prefer OEM Engine mounts or have you tried some aftermarket ones that you liked over the OEM ones?
Thanks for the informative feedback!
Old 09-28-14, 09:26 PM
Tank
Tank's Avatar
Guess no one has ever changed these out..lol
Old 10-05-14, 12:55 AM
angus
angus's Avatar
I've repaced a few sets, and the OEM ones seem to be softer for sure - don't know that the quality is worse but you can move the OEM ones pretty easily by hand a little bit and the aftermarket ones ( I used beck arnley for the 400 and Roca for a 300) I could not budge at all.
I did not feel a noticeable difference in harshness once installed, in fact each time the car felt much better.
Old 10-06-14, 06:52 AM
JJaySilver
JJaySilver's Avatar
I also would like to know. I'm planning on replacing mines soon, also I'm looking at these aftermarket ones from ebay for 126.00 shipped for all 3 mounts: http://www.ebay.com/itm/321043194644, seems like a great deal.
I wanted to go all OEM replacement only, but don't feel like paying over $100 each right now.
Old 10-06-14, 01:56 PM
DMPesso
DMPesso's Avatar
id say go OEM or dont bother replacing them, the car was designed in a way where everything works perfectly together, you dont want hard afermarket mounts with soft oem parts elsewhere, if pretty much everything is OEM, you should keep OEM, especially when it comes to bushings and mounts, the softer ones put less stress on the engine in general so I think lexus made them like this for a reason
Old 10-06-14, 08:02 PM
NorthStyle
NorthStyle's Avatar
How exactly would stiffer motor mounts put stress on the engine? I could see them putting stress on maybe an old or worn out transmission mount, or even making some things rattle in the car a bit, but on the engine itself..?
Old 10-07-14, 06:57 AM
JJaySilver
JJaySilver's Avatar
Yeah nevermind my last posting, I'll stay with OEM. I forgot about Sewell and I don't mind paying 260+ plus shipping for all 3 mounts on that site, compared to their full price. Everything I replaced on my car has been with OEM parts except the spark plugs (NGK). OEM FTW
Old 10-07-14, 06:00 PM
marshun
marshun's Avatar
idunno if anyone else has compared those "oem" vs some ebays. cause i did and mine are the same
Old 10-08-14, 07:10 AM
GSteg
GSteg's Avatar
Some of the cheaper mounts I've bought in the past (not for my GS), looked exactly the same as OEM except they weren't. They were solid rubber instead of fluid-filled like the OEM. They're okay at first but then you notice vibrations later on. If you're close to stock power, just get OEM. I replaced mine 8 years ago and they're still in good shape.
Old 10-27-14, 06:01 AM
Tofubento
Tofubento's Avatar
I have aftermarket ones and I havnt had any issues, from long drives through the dessert , hard braking, hard acceleration, some sliding, they work as they should. They arent stiff like what I would toss in an S chassis, but they certainly do the job well.
Old 11-01-14, 01:00 AM
angus
angus's Avatar
OK, I can update this - my newest addition to my LExus family is a 99 GS400.
I swapped in a new motor and it needed mounts so I bought the beck arnley ones - well this time I got mounts that are super super soft - NOT an issue - UNLESS you have the OBX headers which sit a little close to the steering U-joint.
My car is rubbing the headers against the U-joint in moderate to hard right hand corners and I can feel it.
I noticed today that I could grab the front of the motor with 2 hands and literally move the motor 1" or more in EVERY direction - even back and forth!
I'm guessing they made them super soft to avoid vibration complaints?
I compared this right away to my other GS4 that had the mounts done a while ago with OEM mounts and I can only move that one maybe 1/4"!
So I am going to go with the Megan mounts since they are stiffer than stock and a little vibration in this car won't bother me.
If they are stiffer than stock, it should cure my header issue.
Old 11-01-14, 01:45 AM
clos430
clos430's Avatar
You might wanna check your steering rack bushings, they might be worn. I had that issue when I installed my ppe headers, I bought some solid bushings from figs and it improved a lot.
Old 11-02-14, 09:51 PM
angus
angus's Avatar
Yeah I put in figs when I did the motor.
vollandt
10-07-16 02:20 PM
Studiogeek
Performance & Maintenance
12
03-13-13 08:18 AM
maxwebr
02-04-12 04:18 PM
Nosferatu2
10-06-09 01:09 PM
Quick Reply: GS3/4 ENGINE MOUNTS OEM vs. AFTERMARKET
