26mm Front and 17mm Rear - Correct OEM sway bar size for 06+ IS350
Old 10-01-14, 11:10 AM
azndriver
azndriver's Avatar
Default 26mm Front and 17mm Rear - Correct OEM sway bar size for 06+ IS350
Hello
I was given universal urethane sway bar bushings (26mm and 17mm size),
after searching around and around.
Can anyone confirm that the stock sway bar size are 26mm Front and 17mm Rear
Thank you
Old 10-01-14, 11:28 AM
flowrider
flowrider's Avatar
Received 1,947 Likes on 1,371 Posts
I created the attached about 4 years ago.
Lou
Attached Thumbnails 26mm Front and 17mm Rear - Correct OEM sway bar size for 06+ IS350-isway-bar-specs.jpg
HammerDown
10-23-15 06:11 PM
forthewin
09-25-15 07:39 AM
ay3333
01-08-14 02:01 PM
benbuilt4u
Suspension and Brakes
05-28-11 07:09 PM
prep2
14
03-16-05 07:19 AM
Quick Reply: 26mm Front and 17mm Rear - Correct OEM sway bar size for 06+ IS350
