2011- Pass side brake rattle when coming to a stop
Old 07-22-14, 04:08 AM
joshd250
joshd250's Avatar
Default 2011- Pass side brake rattle when coming to a stop
As title states I recently started encountering a rattling sound when coming to a stop from probably 10mph or less. I've been doing some research on the issue and I came across some but wasn't sure. Is there a TSB for the front brake components?
Old 07-23-14, 12:30 AM
GiantsFan
GiantsFan's Avatar
Did you make sure everything is torqued to spec? Everything is OEM I assume?
Old 07-23-14, 03:03 AM
joshd250
joshd250's Avatar
Everything is OEM correct. I am going to take the wheel off this morning and check it out. What I'm confused about is why it does it at about 10mph or under and not higher
Old 07-23-14, 09:19 PM
joshd250
joshd250's Avatar
Well I took everything off and cleaned the bolts, applied loctite, torqued to spec, and bled that one side and the noise is gone.
Vicqlo
05-09-17 07:09 PM
Vicqlo
03-08-17 09:46 AM
jud149
12-12-16 04:46 AM
greyIS25
Suspension and Brakes
06-03-14 08:13 PM
DINH300
RX - 3rd Gen (2010-2015)
20
07-28-11 08:46 PM
Quick Reply: 2011- Pass side brake rattle when coming to a stop
