traction control flashes with lowered suspension
Old 10-16-13, 06:55 AM
Lexicious
Lexicious's Avatar
Default traction control flashes with lowered suspension
Since lowering car and running 19s I've been having traction control go off when cornering and mainly just in the mornings when cold??? Any input thanks
Old 11-07-13, 06:22 PM
haroon18
haroon18's Avatar
I have the same problem. I think it has something to do with recalibrating the abs sensors.
Old 11-18-13, 10:45 AM
geeznuts
geeznuts's Avatar
You damaged the abs sensor when you installed the suspension. It's that wire that goes on the front spindles. You probably stretched it
Old 11-29-13, 11:38 PM
Lexicious
Lexicious's Avatar
I know of the abs sensor. I've done plenty of suspensions before. Also I don't think I damaged it because the abs/traction control lights never come on, except usually in the morning when its cold and when I'm making slow sharp turns?? I don't get it
Old 02-11-16, 08:17 AM
2k4CamkilA
2k4CamkilA's Avatar
Resurrecting an old thread. I have a 98 GS400 lowered on springs. Last night was pretty cold while I was heading to class and the abs light came on. I got in the car to leave turned on my car no abs light. Backed out and put the car in drive and the traction light came flashed (could hear the traction control engaging) and than my abs light came on and buzz noise(ABS). Proceeded to drive home and nothing irregular occured. Today I drove to work fine no issues but abs light still on.
Dallasguy1
04-03-19 02:29 PM
bofronado2
04-16-14 01:58 PM
zackteee
08-31-13 02:03 PM
D-Boi
Performance
05-15-10 02:53 PM
SC300_704
Performance & Maintenance
04-16-07 08:11 PM
Quick Reply: traction control flashes with lowered suspension
