LS400 Brake conversion done BUT
Old 06-17-13, 09:24 AM
  #31
4eign
4eign's Avatar
bought and put on already but thanx xspsi6.
As far as the pins to recalibrate, my pins are different the video and pic posted. This what i ahve...am looking at the right thing? If this right are there diff pins i should be lookn at?
Old 06-17-13, 07:15 PM
  #32
xspsi6
xspsi6's Avatar
You are running to the exact same problem as I am as my pins look just like that so every diagram I have found thus far does not work for my year gs so I am almost thinking the pins are at the diag port under the hod but nothing solid yet
I am shocked that there is no type of diy yet as I know for sure this is a common problem and as soon as I figure it out I will do a diy.
Old 06-18-13, 01:11 PM
  #33
4eign
4eign's Avatar
^^ patiently waiting and thank you!
Old 06-21-13, 10:32 AM
  #34
xspsi6
xspsi6's Avatar
Ugh I had to give in and have my friend do it who works at the dealer so it was still free but I could not for the life of me find a diy or any info on how to do this for our cars.
Old 06-24-13, 05:16 AM
  #35
4eign
4eign's Avatar
is it all set now?
i had my local dealer look into it while getting service and they told me it was a bad speed sensor. Not sure i'm with them on that. Is the speed sensor located by the brakes?
Old 06-24-13, 06:17 AM
  #36
xspsi6
xspsi6's Avatar
Yea the speed sensor is in the hub and could be the problem if you maybe ripped a wire when installing the brakes? The wires are tiny and could be tough to see since they are inside the rubber line to keep the elements out but if you get it on a good scanner you will know exactly which one could be causing the problem.
Old 06-24-13, 12:36 PM
  #37
4eign
4eign's Avatar
yea the dealer cleared it and did a bunch of ohm test (they wrote it all down and i dont have the paper infront of me) but thats what am they are saying...but they want $400 to fix lmao. trynna see how much my mechanic will charge or if its something i can do.
Old 06-24-13, 05:33 PM
  #38
xspsi6
xspsi6's Avatar
It's easy to do, I bought a pair of them off e-bay for 75.00 and if you need the other I can sell it for 35 shipped if you need?
Old 06-24-13, 06:11 PM
  #39
clos430
clos430's Avatar
Originally Posted by clos430
Check the codes and go from there.
Did you check for DTC's I bet it's one of the sensors.
Should've done this along time ago! ^^^^
Anyways here you go!
https://www.clublexus.com/forums/gs-...to-fix-it.html
Old 06-26-13, 05:38 AM
  #40
4eign
4eign's Avatar
^^^ thanks!
Old 06-26-13, 05:44 AM
  #41
4eign
4eign's Avatar
Do you have the part # for it by chance?
Old 06-26-13, 06:05 AM
  #42
xspsi6
xspsi6's Avatar
No they are used ones so no part # .
Old 06-26-13, 06:41 AM
  #43
4eign
4eign's Avatar
wait...so is the speed sensor the same as the ABS sensor?
bigcat88
04-24-17 05:30 PM
Kstyle55
04-02-12 09:00 AM
nosurprise
02-18-12 06:37 PM
LT 562
10-20-09 04:05 PM
Lexs400
Maintenance
14
05-01-05 08:28 PM
Quick Reply: LS400 Brake conversion done BUT
