Bleeding brakes on GS400 - simple gravity bleed worked for me
Old 05-13-13, 03:16 PM
rwheelz
rwheelz's Avatar
Default Bleeding brakes on GS400 - simple gravity bleed worked for me
I read a bunch of DIY brake bleeding threads and posts/tips. They all referenced needing to pump the brake pedal, turning the ignition on to make the fluid flow through ABS pumps and actuators, etc.
I did a simple gravity bleed as I do on all of my cars and motorcycles and it worked just fine. I did not need to pump the brake, and I did not need to turn the ignition on to activate any pumps to make the fluid bleed out of the rear bleeders. I am not sure what people are talking about. I switched from stock fluid to ATE SuperBlue and bled each corner until the fluid came out dark blue (it does take a really long time, particularly for the rears), so I am confident that the fluid was flowing through the system.
I am wondering whether the ignition-on suggestion has something to do with fluid in some chamber that isn't flushed when the lines are flushed. It is so easy to just let it drip one corner at a time while doing other stuff around the garage. My recommendation is to keep it simple and forego the extra steps outlined in the DIY threads. I should add- my brakes are bled at least a couple times a year (before every track day) so I am confident that the old fluid will mix in and get flushed out as well eventually.
m1tk4
RX - 1st Gen (1999-2003)
20
05-10-19 10:50 PM
cmarino711
05-24-17 01:25 PM
peasodos
04-03-17 09:15 PM
gripau1
01-21-13 05:10 AM
cmc07e
Suspension and Brakes
13
01-02-08 08:52 PM
Quick Reply: Bleeding brakes on GS400 - simple gravity bleed worked for me
