Sc300 prothane bushings with TT lcas.
Old 03-09-13, 02:34 PM
sj408
sj408's Avatar
Default Sc300 prothane bushings with TT lcas.
Hey guys, trying to fit a set of prothane LCA bushings on my car equipped with tt lcas and its seeming the bushings are too small. I was under the impression supra tt lcas and sc lcas had the same size bushings. Can anyone else confirm this?
Old 03-09-13, 03:09 PM
OG Dada
OG Dada's Avatar
Yup. This guy did a few weeks ago.
https://www.clublexus.com/forums/sus...fferences.html
Old 03-09-13, 08:44 PM
estomax
estomax's Avatar
yep, be sure to read all the way through, to avoid the headaches i had
Old 03-10-13, 08:32 AM
sj408
sj408's Avatar
I guess we just didnt realize we had to use the old shell, no biggie after we figured it out.
Biggest complaint about the prothane kit is they require you to remove the inner metal sleeve from the lower rear control arm bushing and that sleeve literally had the bushing molded onto it, was not a press in.
You figure prothane coulda provided that sleeve like other kits on the market do for minimal increase in cost.
Old 03-10-13, 08:36 AM
sj408
sj408's Avatar
Originally Posted by KingPhilip
So phillip, you ended up forcing the bushing into there with the spacer still on the sleeve? without cutting?
And you ended up cutting that spacer off? was noticing that last night when attempting to slide it in
I imagine they will slide right in with correct force as they were in there from the PO
Old 03-10-13, 09:16 AM
OG Dada
OG Dada's Avatar
Yessir. You can find complete detailed pics on my thread, except how I forced it in 'cause that required both hands and feet. Lol
All I did was force the camber side of the LCA with a jack, while assisting the caster side with my hands. The camber side was the one that'll have a tight fit. The crossmember will slice off a tiny bit of the polyurethane, but I was fine with it 'cause it was a solid piece and I don't think it made a difference.
Old 03-10-13, 09:49 AM
sj408
sj408's Avatar
Awesome, that's how they were in the car before
So it shouldn't be too bad thanks!
Old 03-10-13, 12:42 PM
estomax
estomax's Avatar
i still had to use a jack to get my LCA back onto the car too, with that extra spacer on the end there was no way, and i guess it could have if the poly sheared off but i did my best to keep it in one piece and just cut the extra spacer off the end with my trusty angle grinder, and then deburred the edges.
Marko
Old 03-11-13, 09:45 AM
sj408
sj408's Avatar
Marko
interesting, I got the lca in without damaging the poly at all. Guess i got lucky
Old 03-11-13, 09:53 AM
estomax
estomax's Avatar
yeah i didn't damage my poly either. did you cut that extra spacer off the end of the supra arm as well?
Old 03-11-13, 09:57 PM
sj408
sj408's Avatar
No, it went in with the sleeve still there
SC510
Suspension and Brakes
06-19-13 08:07 PM
RLJ
12
12-26-12 11:43 AM
Mike Hughe
09-23-03 02:52 PM
DIrEctQL
SC- 1st Gen (1992-2000)
18
12-04-02 03:00 AM
Quick Reply: Sc300 prothane bushings with TT lcas.
