SC4 steering wheel needs to be turned alot to just move car a lil
Sorry about the crazy thread title, but hard to explain this. Just bought this SC and its stock and very well kept. But recently the PO went cheap with repairs like everything is from Auto Zone and such. Anyway, when you steer the car to the left you have to turn the steering wheel much much farther than you should have to. Its much more noticable ( and scarier) at higher speeds. Then it doesnt just go back to top dead center right away, it takes about 5-10 more seconds of driving before it gradually works its way back to TDC. I know the PO changed the LCA's with aftermarket ones. I'm wondering if something in the labor of that had them disconnect something with the power steering and maybe they didnt pout it back together right? or didnt blled it correctly? or didnt do an alignment? I would presume he did an alignment because common sense says you should after a LCA change but that dont mean crap.Car tracks nice and straight tho. Any suggestions? TIA
1JZ Single SC400
If it is that much swaying and reaction back to center, I would say the rack and pinion is shot or at least the inner and outer tie rods. It could be the bushings alone, but with these symptoms, leads me to believe something more serious.
Sounds like your steering rack bushings. There's no real way to tell (for the most part) if they are bad because only part of them are exposed, and to remove them you basically destroy them.
You can buy them for <$40 though and it's not a difficult job, so I'd do that first. To me, that sounds like your issue.
newpuy
05-11-10 08:00 AM
