What's a good brake grease/lubricant to use on our brakes?
Old 12-27-12, 12:40 AM
mong
mong's Avatar
Default What's a good brake grease/lubricant to use on our brakes?
What's a good brake grease/lubricant to use on our brakes? and does any one know what kind does Lexus (OEM) uses?
Old 12-27-12, 01:20 AM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
I think they use lithium grease
Old 12-27-12, 05:08 AM
jbjones85
jbjones85's Avatar
I'm not sure what the OEM stuff is but I personally use the stuff from the corner autoparts store and it works pretty good.
Old 12-27-12, 11:52 AM
Gville350
Gville350's Avatar
The brake lube that comes in the small square packets at the check-out counter at ANY auto parts store works perfect.
Old 12-27-12, 12:22 PM
Hoac
Hoac's Avatar
Are you talking about antisqueal grease?
Old 12-27-12, 06:34 PM
mong
mong's Avatar
I hear you should only put grease on the calipers and no anti-squeal grease on the shim.. can anyone confirm this?
Old 12-27-12, 06:42 PM
Individual
Individual's Avatar
Looking at the Lexus repair manual, it states to use lithium soap base glycol grease.
It also states, there should be no oil or grease on the shims and friction surfaces of the pads and disc, and apply a light layer of lithium soap base glycol grease to the caliper support pin of the caliper support bracket .
Old 12-28-12, 12:02 AM
mong
mong's Avatar
link please?
Old 12-28-12, 05:32 AM
Individual
Individual's Avatar
I'll give you a screenshot when I get back to work. It's only accessible if you subscribe to TIS, or work for Lexus/Toyota/Scion.
Old 12-28-12, 12:40 PM
Gville350
Gville350's Avatar
I applied the lube to the slide pins, shims, and pad backing. No issues to speak of.
Old 12-28-12, 01:01 PM
Individual
Individual's Avatar
CL picture upload sucks so I had to find a website not blocked from work to upload them:
Old 12-28-12, 01:18 PM
mong
mong's Avatar
^^^^ hmm thanks for the upload!
Old 12-28-12, 01:28 PM
mong
mong's Avatar
I think I'm just gonna use Permatex/Ultra disc brake caliper lube on my calipers and not use any grease on my shims.
http://www.autozone.com/autozone/acc...uestid=3239832
any one have any input on Permatex/Ultra disc brake caliper lube ??
Old 12-29-12, 08:18 AM
Gville350
Gville350's Avatar
^That will work, but the size of the container might be overkill. A small packet available at the checkout counter will do an entire car 2-3 time over. Here's the one I get :
xbladex00
05-19-15 06:25 PM
Arcturus
05-19-15 01:14 PM
gdub686
Suspension and Brakes
09-01-12 05:37 PM
JASP615
GX - 1st Gen (2004-2009)
07-07-11 09:43 AM
98GSOwner
05-30-08 05:57 PM
Quick Reply: What's a good brake grease/lubricant to use on our brakes?
