need some help with the SC maintenance
ok so if your familiar with my build i bought a crappy condition 95' sc300 because it was what i could afford lol.
i need help with this.
i need rear upper control arm bushings. should i buy the TMengineering 160$ set??
major oil pan leaks. the oil pan is leaking onto the rack and pinion which caused the rack to crap out, it needs to be rebuilt and the bushings to be replaced. i will be getting aluminums because they should last longer.
is there anyway you can wiggle out the oil pan without removing components??? couldnt find a thread on this. this is one of the more important things i need help with.
breaks. i will be replacing my calipers and brake hoses. it will all cost about 300$. should i just upgrade to supra TT's or just replace the stock with the other set of stocks i have that i got for free? how much does supra TT brake swaps cost?
so yea major questions:
easiest way to change oil pan gasket?
fix oem brakes or upgrade?
UCA bushings for the rear. TM engineering or do you guys know another place for them?
