I don't have BC's but I'm running Circuit Sport coils with the exact same stiffness (my review thread is only a few threads below). In a nut shell, I ran Tein CS's, Megan EZ's, and now the Circuit Sports and I couldn't be happier with the spring rates. Stiff enough to where you don't clench butt cheek going over road imperfections/rail road crossings, but not too stiff so you can still drive grandma around.
My only concern is different brands of springs are totally different with the coils
Ie 14/12 swift spring is not the same as 14/12 bc sprIngs
I have the same kit but with 16f/12r and I love it.. IMO it rides real smooth.. Ive had megans,ksports, and stance before and these by far are the best!!
I have the same kit sitting on my living room floor....will let you know soon
sounds good mine should come in 2-3 weeks please make sure to update me
thats a lot higher than my spring rate that i ordered!
does the extreme drop kit drop A LOT mroe than the regular?
Well higher spring rate will not compress as much as softer springs which you would want if you are flushed and low. Also higher spring compensate for the cars weight.
SC was heavy and the fronts still compressed like nothing cutting my tires on my frame.
Circuit MS recommend me to run 14/12 as opposed to the usual 12/10 most people get for the extreme drop kit for the 2gs. They've sold a lot of the kits and really know their stuff.
it should be enough for me with the higher dampening, the roads here are pretty smooth. well see how it goes
i have extreme drop 18/16 on my 2gs. Rides great. Not too stiff, not too soft, I would have preferred something a little stiffer to ride flush or poking.
